Getting disconnects from WoW every hour
- Gaming
- Re: Getting disconnects from WoW every hour
21-09-2008 11:57 AM
No idea whats causing it, but it is frustrating.
Switched from wireless to wired and it still happened.
FYI my package is : PlusNet Broadband Your Way Option 3 (Monthly Contract)
My router is : D-Link DSL-2640B
Lapop is : Asus F3Jc
7 REPLIES 7
22-09-2008 11:12 AM
Hiya,
It looks from here like you tried rebooting your router on the 22nd.
Have you noticed any improvement since you did that?
22-09-2008 12:33 PM
I have not forced a reboot of the router for quite some time.
Checked the routers status and it says connection time: 24h 35m 33s.
On your system what time does it say the reboot took place?
22-09-2008 2:06 PM
About a day ago, so it ties into what your router is showing.
Did you play last night?
22-09-2008 3:04 PM
I played wow until about 10:30pm then played somethign else as I got a disconnect and died >:(.
24-09-2008 9:39 PM
Do you use any addons? Since the last couple of patches there have been a couple of issues with various ones. One particular one is QuestHelper that seems to disconnect you everytime you start a timed quest. If you use any it could be worth switching some (or all) of them off for a time to see if it helps. Most likely suspects at the moment will be anything that deals with quests, mapping, or routing info.
25-09-2008 7:23 AM
Ahh ha.
Will dissable all addons and see what happens. (I think I do have quest helper installed)
26-09-2008 1:34 PM
Nice one Paula
Kelly Dorset
Ex-Broadband Service Manager
