Gaming with other things almost impossible over past month
- Gaming
- Re: Gaming with other things almost impossible ove...
08-04-2014 8:49 PM
Modem Status
Connection Status Connected
Ds Rate (Kbps) 4928
Us Rate (Kbps) 448
DS Margin 9
US Margin 22
DS Line Attenuation 45
US Line Attenuation 26
Trained Modulation ADSL_G.dmt
LOS Errors 0
Peak Cell Rate 1056 cells per sec
CRC Rx Fast 0
CRC Tx Fast 0
CRC Rx Interleaved 94
CRC Tx Interleaved 24
Path Mode Interleaved
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count 0
This readout is from a connection that has been running 30 hours since the last disconnect. Currently (since 03/04/14) I am using a D-Link DSL-G604T with the Routertech firmware. I normally use a BT Homehub 3 with one of the very few builds of OpenWRT that runs on it and has been for over a year without issue. Will be trying a HomeHub 2 with a much newer OpenWRT build tomorrow to see if there is any difference.
Essentially one person can be playing a game wile running skype, sometimes two people playing different games and ping times are acceptable. As soon as another person starts downloading something, Youtube, Steam etc. the game starts lagging like crazy. This up until recently did not happen. My brother could be on Dota andI could be watching Youtube or have Steam downloading without the DL limiter turned on and there wouldn't be a problem. Now even Youtube SD videos can elicit shouts of 'My pings over 1000'.
Not that its all him. I play MWO, or at least try to at the moment. I have felt that MWO has tolerated my usual 128-250 ping but recently I have had terrible rubber-banding with the game on occasion reporting that my ping was over 5 seconds!
Its not just gaming suffering, on occasions just regular browsing suffers badly. I guess I am getting some bad packet loss if these TBB graphs are saying what I think they are. The bad moments of lag do seem to line up with the red spikes.
03/04/14
04/04/14
05/04/14
06/04/14 (ignore the big block of red, that was a scheduled power outage)
07/04/14
08/04/14 - Live
Re: Gaming with other things almost impossible over past month
08-04-2014 8:53 PM
08-04-2014 10:29 PM
08-04-2014 10:33 PM
made no difference to BF
08-04-2014 11:02 PM
Which exchange are you connected to (you can find out here https://www.dslchecker.bt.com/)?
I'm surprised you had no issues when gaming/skyping/downloading at the same time looking at your upstream speed.
09-04-2014 12:00 AM
What I am trying to say is that while not fast my connection was steady and intelligently handled what we demanded of it. Now it feels like its barely making above dialup sometimes. Does anybody have any insight about the TBB graphs I posted? is that amount of packet loss and the subsequently high average latency normal?
09-04-2014 8:45 AM
I think one issue might be what the others are doing when you're gaming. It looks like at times your upstream is fully saturated. Have you tried setting up QoS on your routers?
Your exchange isn't 21CN, so PN cannot uncap your upload speed for free. But you are due to be upgraded to fibre before the end of 2015 as part of Superfast Cumbria's plans.
09-04-2014 5:17 PM
I've just taken a look over your line and can't see anything obvious that's causing the issues you're experiencing. I've made a change to your speed profile as it was set a little lower than it should have been, that should take effect within the next 4 hours or so.
We could try and switch off Interleaving, this may alleviate the gaming pain you've been seeing. It'd be great if you could get a traceroute ( http://community.plus.net/library/networking/testing-network-faults/#tracert ) when this does happen so we can have a look.
Does the increase in ping happen randomly or at a particular time?
09-04-2014 5:58 PM
I asked that question because it could make things worse for gaming and may have caused the symptoms reported
Quote from: rongtw TBH i found the pro add on to be useless
09-04-2014 6:18 PM
While usually one would blame this on the trans-Atlantic link or dodgy netcode but when I glance at the TBB graph there is a minor to spike in packet loss. As the MWO servers are in the US and as far as I know the TBB monitors live in the UK I am reluctant to blame it on the traffic going over the pond.
I don't have the ability to directly connect my router to the master socket at the moment as I have no way of getting electricity there at the moment, I'll try to borrow a extension from somewhere. The master socket has nothing but a ADSL Nation style active face place connected to it. There is a single hardwired CAT5 extension running about 5-10m to another socket with the same type of active faceplate where the router is plugged in. I made sure to keep the extension as far away from any parallel mains wiring. 17007 option 2 gives me what I consider a normal low level hiss with no pops or crackles etc.
Interleaving hasn't really impacted gaming to any terribly noticeable degree and I can imagine my line speed taking a dive if I turn it off.
Out of curiosity, how could the pro addon make things worse?
09-04-2014 10:24 PM
Specifically any traffic which isn't identified so comes under "Other" would be Titanium instead of silver so the same priority as Gaming
10-04-2014 7:37 PM
10-04-2014 8:15 PM
- Gaming
