Gaming Usage
- Gaming
- Gaming Usage
Gaming Usage
27-10-2008 10:54 PM
Re: Gaming Usage
28-10-2008 1:42 PM
But In 5 days 6gig is excessive let alone 4gig of gaming, unless you have been downloading patches. As for 4gig worth of gaming have you been Hosting servers and hosting custom maps? That will increase the amout you upload by a lot as everyone that tries to join a hosted server and hasn't got the map etc will get the current custom map even if they just join for a second to check there ping. So try not to allow uploading of custom maps if you do or thats your upload speed maxed out.
As for mine I avgerage about 1-2gig a month of gaming traffic but I only play MMO's atm. So would check with that amount useage that your network is secure if its wireless or if Cat5 cabled then password your pc to stop family using it when they should not be as 4gig is way too much for 5 days use.
Re: Gaming Usage
28-10-2008 2:02 PM
Re: Gaming Usage
28-10-2008 4:09 PM
Ive had no updates whatsoever to download. Ive looked in detail at my usage and i hav 5.7gb total and 60% of that is gaming so sorry for my over estimate (just rounded it up before), but this seems still very high for gaming over just 6/7 days.
Talking to other friends and doing a bit of research it seems people who play online for several hours a day still only use about 1gb over the entire month for gaming. 2 laptops also run wireless off the router (which is connected to my pc) but only 1 of them is used for games (however rarely, usually less than an hour a day).
Today i have been the only one using the internet, i have played counterstrike source for id say 2 hours ish and ive already used 240mb (is this correct?). I very rarely download anything, main reason i switched to plusnet was for gaming. (which by the way has been superb so far, low pings etc).
p.s. this isnt a complaint
Cheers
EDIT - Just to update, today i havent downloaded anything, all i have done is played a few hours on css and have racked up 900mb. Im guessing something is wrong here?
Re: Gaming Usage
28-10-2008 11:34 PM
Re: Gaming Usage
29-10-2008 12:14 AM
Re: Gaming Usage
29-10-2008 8:53 AM
people with Laptops are known to drive around looking for unprotected wifi -
or are you in a remote spot in the country away from a public road ?
Re: Gaming Usage
29-10-2008 10:54 AM
Re: Gaming Usage
30-10-2008 1:06 AM
Re: Gaming Usage
30-10-2008 2:20 AM
Re: Gaming Usage
30-10-2008 1:27 PM
edit - "looks out of window for strange looking person with a laptop".
Re: Gaming Usage
30-10-2008 4:10 PM
i would still change my ecpt to wpa and defentley if you shop or bank online. do you not watch shows like the hustle on bbc 3.
p.s look out for anyone with empty baked bean can or a straining sev as they use this homemade anttenas to increase signal strength its funny but true. i tried it my self when looking at what channels negibouring routers was using to elmenate cross talk and picked up an extra 20+ routers
Re: Gaming Usage
30-10-2008 5:18 PM
Re: Gaming Usage
30-10-2008 5:21 PM
That shows exactly how much your connection has been downloading per day or by hour on a particular day.
Re: Gaming Usage
30-10-2008 6:22 PM
