Gaming Speed and Ports
- Gaming
- Gaming Speed and Ports
15-12-2009 11:04 PM
Hi All,
Quick question about port forwarding. For my PS3 to work on the connection I put the following settings into my router (see attached image) but I have noticed that is not registering any gaming use on my usage stats for plusnet. I am just a bit concerned as this won't get line speed during peak. Are there any settings to be tweaked?
cheers
Joe
cheers
Joe
3 REPLIES 3
Re: Gaming Speed and Ports
15-12-2009 11:05 PM
http://i288.photobucket.com/albums/ll194/quiksilver100/ports.jpg
A link is prob more helpful
16-12-2009 3:14 PM
the gaming didn't show on my usage for a bit , works now though.
16-12-2009 5:54 PM
Try putting ps3 into DMZ
