GEARS OF WAR 2 hosting problems
- Gaming
- GEARS OF WAR 2 hosting problems
Re: GEARS OF WAR 2 hosting problems
19-06-2014 4:38 PM
19-06-2014 5:14 PM
Let us know if this continues to improve the performance and it will be worth keeping in mind should someone see these issues again the in future!
Thanks,
Adam C
21-06-2014 12:26 AM
22-06-2014 7:02 PM
24-06-2014 12:21 PM
Wireshark results would help if you can get these up and running however I know this can be a very complex process to capture the data on console so I'll see if I can grab you some info on setting this up and capturing the data.
Thanks,
Adam C
24-06-2014 12:27 PM
Here are some details from Linn on the same process from a while back -
Quote Please find a guide to running Wireshark here: http://community.plus.net...reshark-for-data-capture/
You would need to set up port mirroring on your router so that the data that's coming through the port where your xbox is connected will reflect on Wireshark on your PC/laptop.
:eth switch mirror capture port 3
:eth switch mirror ingress port 4 state enabled
:eth switch mirror egress port 4 state enabled
This is to capture on port 3 everything on port 4
i.e. Xbox on port 4, Wireshark on port 3
You would need to start to run Wireshark before you start the game and then stop capturing once the game has started. Please then save the file and then zip it and then submit this on a ticket for us to look into.
Full details can be seen in the thread here but what you would need to do is connect the xbox to port 4 and then you would have your PC or laptop connected to port 3 and would mirror the traffic from 4 to 3 so that Wireshark will see all the traffic on the PC or laptop running to and from the xbox.
24-06-2014 10:56 PM
24-06-2014 11:38 PM
Ex-Broadband Service Manager
25-06-2014 5:47 AM
25-06-2014 12:02 PM
26-06-2014 2:04 PM
Would you mind setting up a TBB Graph and keep your connection running?
26-06-2014 8:08 PM
28-06-2014 4:26 PM
30-06-2014 11:58 AM
03-07-2014 3:22 PM
