GEARS OF WAR 2 hosting problems
- Gaming
- GEARS OF WAR 2 hosting problems
13-05-2014 4:04 AM
Re: GEARS OF WAR 2 hosting problems
13-05-2014 12:32 PM
14-05-2014 1:08 AM
15-05-2014 4:40 AM
15-05-2014 11:51 AM
15-05-2014 8:23 PM
15-05-2014 8:37 PM
18-05-2014 9:59 PM
19-05-2014 1:41 PM
We try and reply bas quickly as possible - we're only human.
I very much doubt that Traffic Management is causing the problem if this is all you're using your connection for. If you wanted to purchase a Netgear router, we'd be more than happy to help you set it up.
Have you forwarded the relevant ports for the hosting? I've hosted various games on the TG582n without any problems.
19-05-2014 2:43 PM
19-05-2014 3:11 PM
Have you forwarded port 3074?
20-05-2014 6:13 AM
20-05-2014 4:32 PM
If you're not happy with the router that we have supplied you with, you do have the option to buy your own.
Removing your Firewall isn't necessarily the answer to be honest, I was querying it, just to see if you've tried opening the required port on your Firewall instead.
I'll let other members of the Community provide further advice.
21-05-2014 2:30 PM
17-06-2014 2:01 PM
