Flakey connectivity to steam /valve
- Gaming
- Re: Flakey connectivity to steam /valve
28-07-2014 11:56 PM
30-07-2014 3:20 PM
It's been a few months since I played anything on Steam but I do remember having some issues with it a few months prior to that. It didn't seem to affect everyone that we were playing with but I would see Steam drop its connection completely, I'd be dropped out of chat/voice and show as offline however I was still able to play the multiplayer game I was in seamlessly!
Turned out to be Steam and resolved itself after a few random events over a month. Since then I have noticed I can't connect to Steam when I first fire it up and I have to close it down and fire it back up before I gain connection.
To me it sounds like you're seeing the same thing, Steam drops but you still have an active connection. For me it was just occasional enough to not bother me too much and since then it seems to have cleared up.
01-08-2014 5:28 PM
01-08-2014 5:36 PM
I totally know what you mean, we ended up going round the houses to get voice chat via another method but by the time we had narrowed it down to having one of us run a server at home, the Steam service had decided to pull it's socks up!
02-08-2014 1:55 AM
Here's a review : http://dolby-axon.en.lo4d.com/
Website : https://axon.dolby.com/home.php?user_id=552000
14-08-2014 9:55 PM
If you're signed up to the Beta version, it might be worth going back to the stable version to see if that helps.
16-08-2014 12:18 AM
20-08-2014 9:04 AM
I'd guess that other Broadband heavy activities such as videos & Streaming will have a similar, if not identical effect.
10-09-2014 1:06 PM
Is this particular problem when you are downloading a game or update and you see your progress bar for the download drop off completely, then receive a disk busy message?
10-09-2014 1:57 PM
The dota2 problem was not plusnet as my mate on virgin had the same issue and also a friend in india, Since steam updated the client dota2 is at least fixed.
Personly speaking i have minimum problems with steam to be honest but thats my end so can't comment on other peoples issues.
I don't use other programs to chat with people though so i don't know if this issue is PN or not.
