Firewall problem ? Disconnect From Half Life Source Game Server .
Extreme0
Everytime i turn my Windows Firewall off and try to join a server I get disconnected in 4 secounds. however if i turn my firewall on it won't  Huh Why's that.
13 REPLIES 13
scootie
Re: Firewall problem ? Disconnect From Half Life Source Game Server .
take it you mean the inbuilt firewall and not a thirdparty software firewall?
which version of windows are you running?
i turn mine off and let comodo firewall handle it all in custom policy mode. No idea why turning it off would cause issues, it should be the other way round
Extreme0
Windows XP Service Pack 3
and yes it's the windows firewall
i had this problem for about a year now
scootie
have you tried a reboot after youve switched it off?
take it you have a third party firewall installed with you wanting the windows firewall off
Extreme0
My Router's Firewall is off and i don't have any other Thrid Party Firewall in my system
scootie
why do you want the firewall turned off if you have no other protection other than what your router may be giving you
Extreme0
Just want to test some things and i have got it on just that it werid i would disconnect with the firewall off
leeanthony
Try what Chris said to me, it MIGHT help you too, It certainly helped me
leeanthony
Quote from: leeanthony
http://community.plus.net/forum/index.php/topic,81360.msg665609.html#msg665609
Extreme0
Nope still disconnecting me.
leeanthony
damn Sad i duno then sry m8
Fixes: 1,483
seriously get your router firewall switched back on.
Extreme0
I already have since 2 Days Ago
Extreme0
Oh i see the problem now it automaticly boots you from any Half life source engine game server. Makes common sence too. Well glad thats out the way.  Smiley
