Fifa 15 lag on Xbox 360!
- Gaming
- Fifa 15 lag on Xbox 360!
13-10-2014 7:54 PM
I'm getting crazy lag when i play Fifa and it's so bad that i can't even play as it's jumping every second!
How do i fix this as it's only happened since i've joined Plusnet?
5 REPLIES 5
Re: Fifa 15 lag on Xbox 360!
13-10-2014 8:46 PM
Which router are you using?
Fibre or ADSL? Wired or wireless?
14-10-2014 10:42 AM
Fifa always seems to have issues.I've got a new router and it is working better now.For some reason Fifa doesn't work as well with Upnp enabled.I have disabled it and opened up the ports needed for this game.Since then it has been much more enjoyable with nice smooth gameplay.I realise upnp is an easier option and should work with no problems but I can asure you mine is working much better with it disabled.
Hope this helps.
Hope this helps.
14-10-2014 4:05 PM
On Fibre.
How do i get into the settings to change them?
14-10-2014 4:30 PM
its because upnp only opens 1 port.its a pain if you have 2 xboxs
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
14-10-2014 6:37 PM
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCoQFjAB&url=h...
This is a good link that has various guides for help with lag for Fifa .
