Fifa 10 on PS3 using Plusnet
- Gaming
- Fifa 10 on PS3 using Plusnet
06-11-2009 6:10 PM
Anyone eles having issues trying to play online with fifa 10?
I can very rarely connect to a game and if i am able to the lag is unbeliveable!!!
I have never had a problem until i moved over from sky to PN Pro
Re: Fifa 10 on PS3 using Plusnet
06-11-2009 6:16 PM
There have been some ping issues recently but aparently they are on the way to being sorted out.
07-11-2009 12:44 AM
07-11-2009 5:36 PM
Hi m8, good games too hey!
Quote from: Euge Ironic really because me and another plusnet user itfcdan have played a few game together with no issues but when I play my mate on his sky broadband he is a bit laggy.
The only probs i had were the disconnection issue which has now been patched , last weekend pings were abit higher than normal for plusnet but that seems to be resolved now.
OP have you put your ps3 ito DMZ if not then do it, opens all ports
11-11-2009 1:55 PM
Its annoying to say the least!
11-11-2009 2:13 PM
Does this still apply if my PS3 is wired, there is no option to out PS3 in DMZ in router setup, only wireless devices???
11-11-2009 2:23 PM
thoe on the PN suppiled thomson, the thomson guys have complicated the system by having to the assign the wan ip to your devices instead and when i tried this here it knocked the net off for every devices on the local network including the xbox that had the public ip address.
if you have the thomson i belive this option is on the game sharing page at the bottom called assigen wan ip to devices or public ip. if its not on the game sharing page its defo some where at the bottom of one of the pages
netgears handle dmz'ing beautifuly. you just enter the lan ip you want and thats it
11-11-2009 2:28 PM
11-11-2009 2:31 PM
11-11-2009 2:34 PM
will setting a port forward rule up manuly to open port 1 to how ever high they go( :-\) not give the same result as dmz'ing?
11-11-2009 2:35 PM
11-11-2009 2:38 PM
Incidently, if i cant get DMZ to work and i have to open ports manually, does this look ok?
11-11-2009 2:40 PM
I think.
11-11-2009 2:48 PM
doh think asbo think
yes the thompson does allow ethernet ip's to be placed on the public ip, i should know i did it my self. just hope you get it to work on your network unlike mine. my xbox got the public ip but it was a no go but i didnt try to solve why i had no internet.
so yes you need the ps3 switched on and connected to place in the dmz
11-11-2009 2:53 PM
