Fibre unlimited - Pro Add On
- Gaming
- Fibre unlimited - Pro Add On
29-01-2014 4:29 PM
Re: Fibre unlimited - Pro Add On
29-01-2014 4:42 PM
29-01-2014 5:01 PM
About 14ms from Rapidswitch to my FTTC line
Whoops didn't notice this was about the pro addon
dick:quote
29-01-2014 5:09 PM
- He'd be £5 per month poorer and Plusnet £5 per month richer
- The use of VoIP, gaming and streaming would be worse when there were large background downloads running at the same time
29-01-2014 10:55 PM
30-01-2014 12:06 AM
01-02-2014 6:46 PM
If you're on our Unlimited Product (Introduced as of December 2012) you'll be fine for gaming without the Pro Add On and you won't really see any improvement on performance.
23-08-2015 2:15 PM
I've just added the Pro Add On and already I'm feeling a little cheated. The description on the add on page sounds great (Upgrades your service to a top-class prioritised connection, ideal for online gaming and working from home) but having played around with it for a little while the only difference I can see is that I now get 35 mbps rather than 38!! This lead me to search the forums and I found this thread. I'm aware it's a little old but the comments, in particular Chris Pettitt 's seem relevant. It would appear that this add on would only ever have benefitted customers using older broad band products. If this is the case (and Plusnet know so!) why is it included as an optional add on for my fibre broadband package?
06-09-2015 12:20 PM
07-09-2015 12:39 PM
However, if you suspect you have a problem with your NETWORK which causing issues for gaming, then i would suggest posting in the ADSL or Fibre forums. Those boards seem to be more actively monitored by PN, so you should get a quicker response.
It's unfortunate it's done this way as many of the gamers posting in this section actually have issues with the PN service (either the connection or the cr*p PN router) and rarely get much help from the people who can actually fix it (ie PN not the gaming community).
07-09-2015 12:42 PM
07-09-2015 1:34 PM
07-09-2015 1:59 PM
07-09-2015 2:03 PM
07-09-2015 2:21 PM
If you remove the add-on I'll be able to sort something out for a refund.
