Far Cry 4 - anyone played it yet
- Gaming
- Far Cry 4 - anyone played it yet
22-11-2014 9:43 PM
My only problem - other than being a mean old git - is that my rig won't run it at all (apparently it just refuses to load on a dual core processor) so I need to upgrade
Note the graphics card meets the recommended spec
The best way is a new Intel i5 CPU but that also means a new motherboard, memory and new cooler.as my quiet running one won't fit - about £360 - £400
The cheapest way is to buy a q8400 quad (about £35) from Ebay
Thoughts
Re: Far Cry 4 - anyone played it yet
24-11-2014 7:15 PM
I linked to the same components in this thread but I have no connections to the company other than that I use them regularly.
24-11-2014 7:26 PM
Adding up the components it comes to a £10 saving so I would rather pick my own bits
I would have gone for a Gigabyte H97 board - I find them very reliable - plus a slightly higher spec CPU for only a few pounds extra and Crucial Memory
You may be correct about the standard Intel cooler as they have definitely improved - at present I have a Scythe Mine which is very quiet
I will however look at Overclockers when I do jump as they must have improved from the dire support they used to offer
24-11-2014 7:30 PM
24-11-2014 7:41 PM
Don't know which i5 and other components you were looking at on Scan but the OCUK bundle represents a saving of up to £132, If cases are your thing you could even factor in a Lian Li and still come out cheaper than £360.
@ dvorak: I got a PS4 this time around. Haven't owned a console since the original PS1 but my gaming habits have changed a bit. I have been pleased so far and it fulfils my needs nicely and is quiet. Was also cheaper than upgrading my PC although I miss out on the game mods and sometimes anti-aliasing. For the money very impressed though; it's capable. Oh, there is always TLoU too.
ETA: @ OJ: I favour Asus and MSI as a rule; have used Gigabyte mobos and usually fine although fitting the original i7 into a Gigabyte (cannot recall the model) was nerve-racking; that retention lever. Out of interest - and if you can excuse my nosiness - which i5 are you looking at?
24-11-2014 7:44 PM
M'board £37.99 CPU £139.99 Memory £59.99 = £237.97
Bundle price £227.98
See my edit for what I was thinking about
24-11-2014 7:46 PM
ET: just noticed your comment about support. I have found both companies excellent. I only once felt let down by OCUK and that was RMAing a HDD that was clearly faulty. I had to wait a few days for them to test the unit and bearing in mind I am a regular customer this was annoying. You only needed to power up the drive to know it was broken.
24-11-2014 7:51 PM
Referring to the stupid lever on the Gigabyte boards - that was probably an AMD CPU as the Intel ones have used push pins for ages and they are very easy to install (not like the very old push pin designs which were a nightmare)
24-11-2014 7:59 PM
It was definitely an i7; the original 920 (C0). I can find out which motherboard model it was as I built the system for a friend. Other than that the board has been fine though
24-11-2014 8:10 PM
Interesting for noise level the stock cooler isn't too bad but it gets extremely hot
The reason for Gigabyte as well as the Ultra Durable is the dual bios which has got me out of trouble a couple of times on a failed bios upgrade
Checking on the lever
I forgot - I was thinking about the cooler attachment
24-11-2014 8:55 PM
Asus use a similar system on their boards, luckily I have never had to use it. Both of the retailers mentioned in the thread will flash the latest stable bios onto the board before shipping though, usually for a small fee. I've been forced to do this in the past as I have sometimes purchased boards that won't even post with the CPU I have picked until applying a bios update, and I haven't had a compatible CPU to update it here.
24-11-2014 9:01 PM
I just wish Intel would produce a decent range of CPU's without graphics as it just puts the cost up
25-11-2014 2:30 PM
25-11-2014 4:54 PM
28-11-2014 12:11 PM
So will ignore the whole thing until middle of next year then decide what to do
Re the X5650 - as far as I can tell that will still require a new motherboard and memory so not really a sensible option
