Failure to connect - COD Private Matches - PS3 PSN
topgear6500
Hi, I'm having difficulty connecting to people in my friends list to play private matches on Call of Duty.  I have followed instructions found on the web to put my PS3 in a DMZ through my wireless router - this has worked fine as I can connect to the PSN and play on-line but I still cannot connect to friends for private matches.
I suspect the problem could with the ports at COD uses?
Any help appreciated.
Cheers
TG
1 REPLY 1
matt_2k34
Re: Failure to connect - COD Private Matches - PS3 PSN
if your PS3 is in the DMZ, there is nothing else you can do. the problem lies at their end (you cannot connect to them)
if you tried to host a private game - can they join you? (i would imagine this is the case)
