FIFA12 PS3
- Gaming
- FIFA12 PS3
FIFA12 PS3
01-10-2012 5:52 PM
Firstly, apologies - I know this topic has probably come up before (I think I found a thread from a couple of years ago when I searched google).
I'm having trouble playing FIFA 12 online with the PS3 (using a Thomson router sent by plus net). No problem connecting my PS3 to the internet over wireless, but specifically with FIFA 12 my firewall always says restrictive. I've read lots of stuff on the internet before posting here but I'm not having much luck! It will often cut out during games even though my internet connection stays strong. Does anyone have any idea how to loosen the firewall settings, I've read alot that it should be set to open rather than restrictive?
I've posted a ticket to plusnet for this too but had nothing back.
Thanks for any help,
Danny.
Danny.
1 REPLY 1
Re: FIFA12 PS3
01-10-2012 7:09 PM
what ive done is have the ps3 run off a wired internet connection fromt he router.
checked the ip adress from the ps3 and then in the router webpage set that ip adress to DMZ....basically oens all the ports on the ps3.....note dont set this for your pc by mistake lol
