FIFA 11 Lag ( HELP ! )
- Gaming
- FIFA 11 Lag ( HELP ! )
Re: FIFA 11 Lag ( HELP ! )
11-03-2011 12:12 AM
11-03-2011 12:19 AM
11-03-2011 12:23 AM
11-03-2011 12:27 AM
the ones i have highlighted are your router talking to your devices asking where they are basically, the green ones are more likely to be from your xbox
to your re post, yeah just look at a fair few that are more likely to come from your xbox instead of router or background traffic, if most are 0ax0 then it most likely is not a PN prioity issue, if the port is 3074 then they are defo xbox packets and you can be sure the ds field should be 0xa0
11-03-2011 12:32 AM
11-03-2011 12:37 AM
11-03-2011 12:56 AM
11-03-2011 2:56 PM
might find this useful
http://community.plus.net/forum/index.php/topic,94089.0/topicseen.html
think this board needs making then matt might pop in to post the same reply he did an hour ago in that thread
16-03-2011 12:14 AM
Uptime: 5 days, 11:50:04
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 948 / 5,848
Bandwidth (Up/Down) [kbps/kbps]: 444 / 5,464
Data Transferred (Sent/Received) [GB/GB]: 1.00 / 9.29
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 28.0 / 46.0
SN Margin (Up/Down) [dB]: 20.5 / 6.0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,550 / 0
FEC Errors (Up/Down): 1,387,392 / 162,905,671
CRC Errors (Up/Down): 26,918 / 5,215
HEC Errors (Up/Down): 60 / 50,977
17-03-2011 2:15 AM
17-03-2011 1:08 PM
if you believe the packets in your capture are showing as fifa 11 not being picked up 100% right by the current sig PN are using then raise a ticket 4mb file size max so about 4 seconds max capture
am shocked no PN staff have entered the games board to help solve this one for you. must the OP sing the PN theme tune heaven 17 - Temptation to get noticed?
18-03-2011 10:47 AM
appreciated if you could post a quick guide for the op to check they have the xbox fully open?
18-03-2011 3:24 PM
Regarding your problems Y2J, give me an hour or so and I'll get back to you...
18-03-2011 3:59 PM
Quote from: Asbo who knows how to dmz on the Thompson?
Does this help?
18-03-2011 4:08 PM
