FIFA 11 Lag ( HELP ! )
- Gaming
- FIFA 11 Lag ( HELP ! )
10-03-2011 10:43 PM
I have got on to plus net they told me to do a wire shark, did that could not upload the file thru help assistant, they say it is prioritsed properley.
Dont have a clue what any of the wireshark info means the tutorial was diffrent to mine.
Im starting to think i should go elsewhere because my mates have no problems playing in peak times with sky talk talk aol etc, i cant get my head around it at all.
I think its classed as peer to peer traffic which i think is wrong as millions of people play this game and just plysnet throttle it?
Again i cant get my head around it.
HELP MEH
Lee
here are some stats if you need em :
Uptime: 0 days, 10:21:40
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 968 / 5,664
Bandwidth (Up/Down) [kbps/kbps]: 444 / 5,464
Data Transferred (Sent/Received) [MB/MB]: 101.33 / 561.08
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 28.0 / 46.0
SN Margin (Up/Down) [dB]: 21.0 / 5.5
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 163,488 / 7,418,607
CRC Errors (Up/Down): 5,141 / 464
HEC Errors (Up/Down): 19 / NA
Xbox360
Information
Status: Active
Type: Gaming Console
Connected To: ethport3 (Ethernet)
Addressing
Physical Address: 00:22:48:b0:04:eb
IP Address Assignment: DHCP
IP Address: 192.168.1.65
Always use the same IP address: Yes
DHCP Lease Time: Infinite
Game or Service
Xbox Live
Re: FIFA 11 Lag ( HELP ! )
10-03-2011 11:07 PM
i use to do alot of wiresharking on the xbox 360 in a bridged mode setup using laptop wireless when i was a customer, not because i had issues with gaming but the dashboard vids etc
10-03-2011 11:10 PM
I dont know if my xbox is set up propely with my thomson router, dmz port ,fowrord etc .
10-03-2011 11:21 PM
never played fifa but from memory its one game that raises its ugly latency head more than most around here, tends to be on the ps3 tho which uses a bigger port range for games.
http://community.plus.net/library/faults/using-wireshark-for-data-capture/
10-03-2011 11:26 PM
10-03-2011 11:38 PM
mad this
im on extra with 60gb
10-03-2011 11:41 PM
10-03-2011 11:47 PM
then the other two highlighted give you the info you need, that cap is of a streaming music vid on muzu.tv but there is other background packets on there
10-03-2011 11:54 PM
10-03-2011 11:58 PM
i must ask this but your are expanding the section by the box at the side of internet protocol right?
under help, about= Version 1.4.4 (SVN Rev 36110 from /trunk-1.4)
11-03-2011 12:01 AM
11-03-2011 12:03 AM
11-03-2011 12:06 AM
11-03-2011 12:10 AM
11-03-2011 12:12 AM
cheers
