Excessive Ping
- Gaming
- Re: Excessive Ping
Excessive Ping
20-01-2013 5:00 PM
Over the last three days I have seen a massive increase in the Ping /Latency to the TF2 MvM (Team fortress Mann v Machines )servers which I have been playing on now for over ten months.
Previously Ping Latency has been pretty good averaging 38, now the servers I usually play on are unplayable at over 300+ pings.
What I'm wondering is why?, is this a Plusnet thing where loads of people have jumped on board over the Christmas advertising campaign or something else.
The servers are Uk based and up-to three days ago had a very good ping/latency.
And I can't see Team Fortress 2 on the list of Games which Plusnet allow, how exactly do I make sure they are not blocking restricting the Servers.
Can anyone shed some light on this?
ThisLd.com 5.39.37.4:27015 well over 300+ ping =(
Thanks.
Bit gutted I can't use my Fave servers right now.
[Moderator's note by Adie (dvorak) all caps title edited as per Forum Rules]
Thanks.
3 REPLIES 3
Re: Excessive Ping
20-01-2013 6:08 PM
Try now?
We've had a network interface issue the past couple of days. We've just fixed it.
Kelly Dorset
Ex-Broadband Service Manager
Re: Excessive Ping
20-01-2013 6:44 PM
traced the IP and 2 issues, a number of PN spikes and also looks like its the transit host in France at fault as well. Checked a few other servers I use and no issues repeated just with that host in france
FTTP 500 regrade from Tues 28th November
Re: Excessive Ping
20-01-2013 6:55 PM
Thanks Guys.
The ping is still much higher than normal but better than it was.
Cheers for help.
Cheers for help.
