Everquest 2 (eq2) patcher having issues.
dalehurlin
Hi
I see on the EQ2 forums that a number of plusnet customers are having an issue trying to use the EQ2 patcher.
The issue does not seem to be internal to Plusnet but all or most of the people seem to be plusnet clients.
I wondered if anyone had a fix, if anyone had already raised a call or if plusnet were already looking into it.
My ping (removing the first couple of nodes for anonymity reads as follows
  3    18 ms    24 ms    20 ms  irb.13.pcl-cr02.plus.net [84.93.249.130]
  4    22 ms    19 ms    19 ms  195.99.126.98
  5    20 ms    19 ms    19 ms  core4-te0-0-0-27.faraday.ukcore.bt.net [109.159.249.185]
  6    23 ms    *      18 ms  peer2-et-3-3-0.faraday.ukcore.bt.net [62.6.201.165]
  7    18 ms    19 ms    18 ms  213.137.183.34
  8  103 ms  103 ms  103 ms  ixp1-xe-11-0-0-0.us-ash.eu.bt.net [166.49.208.59]
  9    *        *        *    Request timed out.
10  110 ms  110 ms  109 ms  pit-ten2-1-ash-ten7-2.bboi.net [66.216.1.206]
11  117 ms  116 ms  115 ms  col-ten2-2-pit-ten2-2.bboi.net [66.216.1.102]
12  124 ms  138 ms  143 ms  ind-ten1-1-col-ten3-3.bboi.net [66.216.1.110]
13  126 ms  125 ms  125 ms  chi-t1-3-ind-t1-4.bboi.net [64.127.128.184]
14  166 ms  170 ms  165 ms  veg-t1-3-chi-t1-4.bboi.net [64.127.128.191]
15  171 ms  167 ms  167 ms  switch-vegas-bboi.bboi.net [66.186.192.46]
16  169 ms  166 ms  167 ms  be81.las-core7-1.switchnap.com [66.209.64.109]
17  166 ms  168 ms  166 ms  te0-3-0-1.las-agg7s3-2.switchnap.com [66.209.72.14]
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *        *        *    Request timed out.
21    *        *        *    Request timed out.
22    *        *        *    Request timed out.
23    *        *        *    Request timed out.
24    *        *        *    Request timed out.
25    *        *        *    Request timed out.
26    *        *        *    Request timed out.
27    *        *        *    Request timed out.
28    *        *        *    Request timed out.
29    *        *        *    Request timed out.
30    *        *        *    Request timed out.
A link to the EQ2 forums is here https://forums.daybreakgames.com/eq2/index.php?threads/cannot-patch-game.567722/ (p.s. Moderators if this is not allowed apologies and please delete the link)
You can see what some people have tried.
