Double Double Vision Vision
- Gaming
- Double Double Vision Vision
02-05-2013 4:36 PM
Re: Double Double Vision Vision
02-05-2013 4:41 PM
02-05-2013 4:44 PM
02-05-2013 4:45 PM
02-05-2013 4:48 PM
02-05-2013 4:51 PM
@Adam Gunner gaming glasses. http://kotaku.com/5123560/gunnar-gaming-glasses-review-why-buy-wi+five
03-05-2013 9:26 AM
I get exactly the same, and even worse if I've been looking at one of those stereoscopic 3d image poster things - you know, like these ones: http://www.eyetricks.com/3dstereo4.htm
06-05-2013 4:57 PM
08-05-2013 11:13 PM
09-05-2013 9:29 AM
Also get your blood pressure checked, if its higher than normal then it can affect your eye sight, especially if your eyes tired/overworked.
Yes both bits of advice from experience. I had the same 2 years ago and new glasses and seeing my doctor helped considerably.
09-05-2013 12:52 PM
I did have a gaming break for 3 days so maybe that helped.
I don't wear my glasses when gaming as it's on a 42" TV but maybe I need to visit the opticians
09-05-2013 1:00 PM
12-05-2013 11:00 AM
Quote from: Steve_M All4One Do they help? Is your post from experience with a pair?
Not personally tried them for a long period, but they seemed alright. Used to work for Blizzard and there were a few guys using them but I honestly don't know whether they're just for looks or can help, whether that be just a specific group or anyone using them.
10-11-2013 2:50 PM
Quote from: All4One
I've just ordered a pair, I'll update this sometime.
10-11-2013 5:12 PM
Thank you for revisiting the thread and I look forward to what you have to say about them
