Dota 2 lag spikes
- Gaming
- Dota 2 lag spikes
Dota 2 lag spikes
31-03-2014 5:34 PM
I've been experiencing network lag spikes and stutters when playing dota 2, especially if I have a VoIP program running at the same time as playing. It doesn't seem to matter what time I play, it's always just as bad. I haven't known for this problem to happen with any other multiplayer game that I play, but I have to admit that I don't play many other games.
My ping is always very low in-game, so it's just spikes rather than constantly high ping.
I've ran a wireshark capture already, that I supplied the support centre team with. I was spectating a game on an EU server when I recorded this capture. The traffic seems to be managed correctly, so I'm wondering if maybe it's a problem with my line?
I use wireless internet, and unfortunately, wired internet is not an option in my current living situation. I get a very strong signal strength, and don't have problems with any other application, so I doubt it's the wireless card that's the culprit.
Thank you to anyone who reads this.
Re: Dota 2 lag spikes
02-04-2014 1:48 PM
Is there a way on Dota 2 to see how much bandwidth the game is using?
15-04-2014 10:14 PM
http://www.amazon.co.uk/TP-Link-PA411KIT-AV500-Powerline-Adapter/dp/B0084Y9N3O/ref=sr_1_6?ie=UTF8&qi...
21-04-2014 10:43 AM
I used to game on wifi and every 5 minutes or so, it would spike and I couldn't do anything. Only solution for me was a long ethernet cable. Never had problem since.
16-05-2014 1:45 AM
My bad... seems that I was wrong on this. Just ran Wireshark and the data is 0xA0, as it should be.
But, if I have a 6.5mbit connection, and Netflix uses 3Mbit/s when streaming, DotA only uses (at most) 0.3Mbit/s. The two should be able to co-exist, right?
Instead I get complaints from my son that he's lagging out if anyone tries watching TV.
Something doesn't add up. Any clues?
16-05-2014 5:20 AM
http://www.digitalsociety.org/2010/06/how-video-streaming-can-ruin-voip-and-gaming/
Doesn't solve the problem, but does explain why a fast enough connection is still being saturated by Netflix.
21-05-2014 6:14 PM
21-05-2014 6:19 PM
Have you 100% confirmed that the Dota lagging starts when you start the film?
Ex-Broadband Service Manager
29-05-2014 11:17 AM
I raised a ticket on this issue and got a very empathetic and supportive response but, unfortunately, whatever actions were taken appear to have crippled the line further and I'm now only getting 2mbit download, when I used to get 6-7mbit.
I'm stumped.
29-05-2014 3:26 PM
29-05-2014 11:46 PM
31-05-2014 7:39 PM
02-06-2014 12:36 PM
Good news is that the line has finally retrained at what appears to be a sustainable 7808kbps (SNR varies between 6-7Db). Still getting FEC errors (about 1.1k per hour) but CRC seems to be down to 7 or so per hour, which seems at least passable, no?
But, despite doing everything to monitor and improve the line quality, DotA still lags terribly when I launch a Netlfix stream.
05-06-2014 3:58 PM
I've just had a look at this here using a PC with DOTA2 on and an Android running Netflix.
My ping was about 80ms or so normally. It jumped to between 90 and 100 for about 2 seconds when started a Netflix stream, but then went back down to 80 very quickly. I didn't notice any change in the game when this happened.
I played for about 10 minutes while the Netflix was streaming and didn't have any problems and the ping remained static at about 80ms or so.
What device are you running Netflix on? Perhaps we could try and use the same Netflix client that you're using.
Apologies to Kelly for ruining his reputation...!
Matt
Edit: Just tried with a Windows 7 PC running Netflix - no issues, and also tried Windows + Android concurrently, no problems. Are you using a TV or set top box?
Edit2: Could you try connecting to one of the new BNG gateways? It does traffic management slightly differently and I'd be interested to see if you still get the problem. Load up http://usertools.plus.net/@gateway and look for a gateway with BNG in the name - PCL-BNG01 for instance - and then try again, thanks!
10-08-2014 11:10 AM
Thanks for the reply. Apologies I didn't see it sooner - truth is, after several contacts with support and trying everything I can think of, I've just been putting up with the problem. It hasn't been any better.
Netflix is perhaps a red herring. Pretty much any data causes the problem. We get pretty good throughput for streaming services, but they ALL seem to take priority over the DotA traffic. Even low-res YouTube videos cause it to crap out.
The devices my family have been using Netflix/4oD/iPlayer/Spotify (not all at the same time, I might add!), etc on range from set top boxes to Android to Windows. I've been monitoring the connection, and it's been variable - periods of stability, with retrains and errors, but settling down eventually somewhere around 6Mbit.
I wondered if WiFi contention was a problem, but this is a 54Mbit Wifi router, right? Still, to remove doubt, I plugged in directly to the router via the cable, and still got problems.
Checked the gateway. All it says is that I'm connected to ptw-ag04. I can't see any option to change anything though. Am I missing something.
Thanks for your help. Would love to solve this and have a harmonious house!
