DoS attack: ACK Scan, whats does this mean ?
- Gaming
- DoS attack: ACK Scan, whats does this mean ?
27-10-2012 9:17 PM
This is taken from my new netgear N 300 router that i got yesterday.
This is the one here http://www.amazon.co.uk/Netgear-Wireless-N-Router-Modem-connections/dp/B003FS40KU/ref=sr_1_2?ie=UTF8...
[DoS attack: ACK Scan] from source: 84.93.230.186:80, Saturday, October 27,2012 20:42:24
removed most of it now as its ok now
7 REPLIES 7
Re: DoS attack: ACK Scan, whats does this mean ?
27-10-2012 10:02 PM
I had a load of those and they were all innocuous so I stopped it logging them
27-10-2012 10:03 PM
hmm ok i guess its somthing maybe just to monitor just incase
27-10-2012 10:06 PM
The problem with monitoring it is that the router log has a finite size and those reports rapidly fill it
http://community.plus.net/forum/index.php/topic,98237.0.html/
27-10-2012 10:07 PM
Ok. I've had a quick look through the IP addresses that appear to be hitting you.
173.252.101.18 - This IP address belongs to Facebook. I assume this is a website that you have been on.
This information can be found at: http://www.whois.net/ip-address-lookup/
If you type in the IP addresses on the list you will see that a lot of them are from general websites that you have been on.
After the IP address you'll see a prefix such as: 173.252.101.18:80 This little section shows that Port 80 is being used. (Port 80 is used for HTTP - AKA: Web Browsing.
I don't think there is anything to worry about, perhaps your router just being a little over protective and logging everything, which, it is well within it's right to do for you.
Just for your piece of mind IP Address: 84.93.230.186:80 is Plusnet as you have been on these forums, every time you move from page to page on the forums you'll most likely see a hit on the list you've provided there.
If you've any further questions, let me know
27-10-2012 10:19 PM
cheers i feel you have helped enough im at rest bow
Enjoy the rest of your weekend.
27-10-2012 10:24 PM
He'll be able to blame his missus for facebook
Thanks for all that Chris, that saved me a task, your Out of Office hours help is very very much appreciated.
And thanks Jim for your info that is helpful as well, it explained it very clearly and saved me from digging.
28-10-2012 1:58 AM
i feel its me who need to thank everyone ... Thanks again
