Destiny
agentseabass
Destiny
Hi All
I am new to Destiny and PS4. Thought I'd get Plusnet as the reviews are so good. I am also experiencing these fault codes(flatworm/beaver) I am not to sharp on changing my router settings and  am slightly worried that I will make things worse by changing the wrong thing. Can anybody let me know that if I buy a new router, as I have read that the problem could be with the technicolour one Plusnet supplied. Would this be an easy solve. I was thinking of getting a TP-LINKN300. I have seen some reviews and this seems to be an ok router.
Tech guys from Plus net. Can you please simplify the description of how I can change the settings on the router you supplied?
My NAT is Type 2
My Upnp is enabled
This is as far as I can go so far, any help is very much appreciated
Thanks in advance
Agent Seabass
agentseabass
Re: Destiny
Cry
Mathias
Re: Destiny
Plenty of router questions on the forum, so if you're wanting advice on alternatives to the PN supplied one, maybe have a look through those.
Personally i have bought a different router as i've head others have difficulty with the PN router and gaming.
PN as a whole though have been very good for me and i have a very stable, good speed low ping connection.
If you are wanting to have a bash at configuring the PN router for gaming, there are guides on the FAQ section and links to it in other threads in this forum.
ghos7em1
Re: Destiny
put your ps4 in dmz.only thing that works with that game if your using technicolor router.its a poor,cheap router.i replaced mine with a netgear router.
agentseabass
Re: Destiny
Hey  Smiley
Thanks or the reply, is the put the play station in DMZ zone a play station setting or a router setting?
Ta
Agentseabass
ghos7em1
Re: Destiny
log into your router>find your ps4( think under home network) click configure and choose all ways use same ip.then put that ip in dmz it will be under firewall.then restart router.
agentseabass
Re: Destiny
so all seems to be okay so far with these settings, thanks for the help.
ghos7em1
Re: Destiny
any time m8 Smiley
