Destiny - Anyone having connection issues.
- Gaming
- Re: Destiny - Anyone having connection issues.
14-09-2014 5:32 PM
These are the ports that Destiny require:
7500-17899 (TCP) Outbound
30000-40399 (TCP) Outbound
35000-35099 (UDP) Inbound and Outbound
3074 (UDP) Inbound and Outbound
Has Destiny been added to the list of games of allowed traffic within PlusNet's network setup? Just want to rule out everything before taken drastic measures (like setting up a DMZ, etc)
14-09-2014 7:11 PM
14-09-2014 10:36 PM
14-09-2014 10:40 PM
15-09-2014 9:41 AM
Ex-Broadband Service Manager
20-09-2014 4:01 PM
20-09-2014 4:14 PM
20-09-2014 5:36 PM
20-09-2014 5:49 PM
20-09-2014 8:25 PM
20-09-2014 10:18 PM
Quote from: ghos7em1 if you have gamemode enabled then it will delete all the udp ports that you opened thats what happen to me,turn off gamemode and most of your gaming problems will go and turn upnp extended security off.plz test it
Found it. It was disabled to begin with. Made no difference...
21-09-2014 12:42 AM
21-09-2014 10:18 AM
Quote from: ghos7em1 if upnp extended security is disabled only thing you can do is use dmz option,if that dont sort your problem then you will have to buy a better router
uPnP Extended Security has been turned off now.
PlusNet tech guys, any Telnet commands that I can use to turn TCP/UDP flood protection on the Thomson /Technicolor TG582n router?
21-09-2014 9:45 PM
22-09-2014 6:46 PM
Quote from: Ryoga
uPnP Extended Security has been turned off now.Will find out if that has helped.Nope, didn't help one bit. Still getting 'Beaver' error message upon connecting to the Tower part of the game.
When the error happens, are you able to see the Technicolor router?
The reason I ask is that Destiny seems to do something funky to mine. At the time I get disconnected and get an error, the router will show only the broadband led, then the ethernet, Internet and wifi leds, then the broadband led, then back to ethernet internet wifi. It will repeat this about 5 times, then either resets, or recconects.
Destiny is the only time this happens, so its something the game is doing.
