DNS for Static Ip address on xbox 360
thecount
Can anyone tell me what the Primary and Secondary DNS should be when entering them for a static IP address for xbox 360
Thanks in advance
David
2 REPLIES 2
Steve
Seasoned Pro
Re: DNS for Static Ip address on xbox 360
Wont It just run through whatever your DNS Settings are via your router?
If life gives you lemons, make lemonade.
thecount
I have magaged to set it all up and my xbox has static IP, MY IP address is 192.168.11.64 and I have given the xbox 360 and address of 192.168.11.64 , I have then opened to ports on my routes and still NAT type of moderate and then I put it in the DMX and still moderate.
Has anyone else got any ideas
My router is a Buffalo router
