Crysis 3 and my rig - a bit of guidance needed
- Gaming
- Crysis 3 and my rig - a bit of guidance needed
04-12-2012 4:40 PM
http://www.examiner.com/article/crysis-3-system-requirements-revealed-direct-x-11-required
So an upgrade is needed.
The obvious GPU is the Nvidia 650Ti but - and it is big BUT - will I be severely CPU limited as I have an Core 2 duo E6750 and getting any sensible improvement will mean a new motherboard and processor and memory - not even remotely feasible
Re: Crysis 3 and my rig - a dit of guidance needed
04-12-2012 5:17 PM
Another thing you might have to upgrade is your power supply, I got a 560 Ti and my PSU was not adequate, so I had to fork out another £80 for a PSU with 38 amp rails, as my original PSU only had 20 amp rails. It really is a nightmare upgrading.
Re: Crysis 3 and my rig - a bit of guidance needed
04-12-2012 5:29 PM
I suspect it'll run fine, that isn't a bad CPU by any means and I think memory will be a bigger drag than cpu so if you've got 4 or 8gb in there you'll be able to run it at better than minimum settings.
04-12-2012 6:15 PM
Power supply should be OK as it is a Corsair vx550w with a single 41amp 12v rail bought for that reason among others
04-12-2012 10:52 PM
http://www.ebay.co.uk/itm/Intel-Core-2-Quad-Q6600-2-4-GHz-Quad-Core-CPU-/281030765876?pt=UK_Computin...
Intel CPU benchmarks
http://www.cpubenchmark.net/
05-12-2012 5:50 PM
Fortunately I won't need to do anything until Crysis 3 comes out next year
05-12-2012 6:00 PM
reason i ask is there are plenty of offers around for bundles , so it may work out better to buy a bundle rather than just a few odd bits
05-12-2012 6:08 PM
I have just checked memory prices - they are cheap at present - worth considering a complete replacement at the time
My present rig is
Motherboard Gigabyte GA-P35-DS4
CPU E6750
GPU Nvidia 8800GT
The motherboard will take up to a Core 2 quad Q9650 (very expensive) but a Q8000 series would be definitely worth looking at as even looking at new they are about £120 OEM
However looking at the I3 prices that would be very interesting should I decide that the CPU is struggling
The one thing which is clear is that after replacing the GPU the next step would definitely be a new motherboard and CPU either as a package or as bits so that I can get the quality I want - must check the compatibility of the CPU cooler which wasn't cheap and must fit the new motherboard because it it doesn't that will screw up the whole thing Aargh! it will only support the Q6600 CPU (not sure why it won't support the Q8000 series - perhaps it just wasn't available when it was marketed) but I am not sure that is correct - it depends on the mounting pins so much more investigation needed
05-12-2012 9:04 PM
http://ark.intel.com/products/42112/Intel-Core2-Quad-Processor-Q8400S-4M-Cache-2_66-GHz-1333-MHz-FSB
07-12-2012 6:13 AM
You could always think about hardware accelerated sound and network cards to help reduce the load on your cpu?
17-12-2012 2:56 PM
Reason - these new hard drive connectors are too easy to dislodge
The bit which surprised me is that although the change was from one Nvidia card to another it needed to reinstall the drivers and then needed a reboot
