Counter Strike Global Offensive Issues
- Gaming
- Re: Counter Strike Global Offensive Issues
30-04-2014 2:19 PM
I'm an avid CS:GO player but I am hampered by the fact that every time I try to play a competitive game via matchmaking, I am told in my party of friends that I failed to accept the game, when in fact I had no accept button to click and neither have my friends. It gets stuck on the confirming match, but then it says "A game was found for you, but John failed to accept."
I've Googled this a lot, and found numerous things on Steam forum that haven't helped at all.
I login to my router, disconnect the connection, then reconnect it and all is fine and dandy, but maybe 2 or 3 games later, it happens again resulting in my resetting my connection. I've also turned my router off and on at the power countless times, but this takes a lot of time and wastes not only mine but my friends also.
I also have a problem with my router where the red light for internet is on, yet I can still browse and go about my business as usual.
I'm pulling my hair out with this connection now, as at my old address on a 6mb down and 0.2 up, it was completely fine, and this also doubts weather I want to enter a 24 month unlimited fibre contract with you.
It's either a fault in the line, a fault in my router or something in the faceplate which is the original from the previous tennant.
My setup is from the phone socket downstairs, into a filter, into an RJ11, into the router upstairs. Worked fine at my last address, seems not to be the case here.
Thank you for reading
30-04-2014 8:20 PM
Could you post your router stats?
01-05-2014 4:23 PM
My router is a TG582n with 8.4.4.J firmware?
dick:quote
01-05-2014 5:21 PM
01-05-2014 7:53 PM
02-05-2014 10:10 AM
I think I've found out the cause:
Quote Current implementation of player's game client tries to ping the game server before it presents the player with the green "ACCEPT" button. If the game client fails to ping the game server then the match will not start and an error message explaining that player failed to ping the game server or failed to accept the match is shown. There would be no "reconnect" option since the match didn't get fully accepted and didn't start.
There's some potential fixes (http://steamcommunity.com/app/730/discussions/0/864956555067235792/): Steam-> View -> Settings-> In-Game -> set "In-Game server browser: Max Pings/Minute" to 250
Apparently, the reason it happens is that the NAT tables on your router fill up and cannot accept any new connections. When rebooting the router, you clear the NAT tables and this is why it fixes the issue.
02-05-2014 11:30 AM
Do other routers perform better to this regards, if so how?
02-05-2014 11:34 AM
02-05-2014 6:20 PM
05-05-2014 8:11 PM
12-05-2014 2:19 PM
23-05-2014 2:11 PM
08-07-2014 6:46 PM
Starting to think it's this router that is broken as it's fine after rebooting (power off switch), and sometimes it works if I login and disconnect then reconnect the connection.
09-07-2014 9:34 AM
09-07-2014 1:11 PM
Today I've literally been playing one competitive, resetting, one competitive, resetting, one competitive etc etc.
