Couldn't play any games online, upgraded to pro but still no different
- Gaming
- Couldn't play any games online, upgraded to pro bu...
23-05-2010 12:11 PM
Got the email saying the product change is complete but I still can't get onto any games, get a connection lost message after a few seconds, any ideas?
My exchange isn't LLU enabled so plusnet pro looked like it's be ideal and I really don't mind paying the extra money if it gives me what I want!
Re: Couldn't play any games online, upgraded to pro but still no different
23-05-2010 12:22 PM
Quote Link Information
Uptime: 0 days, 0:53:17
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 11.5 / 17.5
Line Attenuation (Up/Down) [dB]: 8.5 / 13.0
SN Margin (Up/Down) [dB]: 26.0 / 11.0
Vendor ID (Local/Remote): TMMB / P
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): 0 / 4
23-05-2010 1:24 PM
looking at your stats i would say your on the 20cn adsl product or the value capped 21cn product. either way your on pro and if your exchange is enabled you should be on the adsl2+ service.
looking at the error rates in an hour and the limited ping results i cant see anything that would cause issues.
can you try running ping plotter or run a plain "ping -t bbc.co.uk" from the command prompt use crtl+c to stop the ping and copy paste any bits that have wild flucts in pings.
insure nothing else is using your conection at the same time as this will effect the ping esp on a 448kbps up connection
23-05-2010 1:55 PM
ADSL status:
Enabled as of 09/06/2004
ADSL Max status:
Enabled as of 31/03/2006
SDSL status:
Not available
21CN WBC status:
Not available
FTTC status:
Not available
Those that say 'Not available' had a red cross by them.
Will do a BBC ping shortyl.
25-05-2010 10:35 PM
Will report back if I get any more issues.
26-05-2010 9:07 AM
http://usertools.plus.net/exchanges/
26-05-2010 12:31 PM
Quote BT is reporting that some of the virtual paths at this exchange are not operating within BT Wholesale's planning guidance, although they are still operating within the product specification.
At busy times, your ADSL connection may operate at a reduced speed, although not all customers on your exchange may be affected. You should only contact support if there is no current ETA date set.
The ETA fix time is: 23 May 10
Record last updated: 21 May 10
Historical information for this exchange:
Status Date
red 07 May 10
red 30 Apr 10
red 23 Apr 10
green 16 Apr 10
red 09 Apr 10
Would that explain it then? On a few speedcheckers I was getting rubbish speeds last night, gta was playing ok though.
My exchange code is EASMN / Southminster, Essex. Am I on a ADSL2+/21CN product now? That exchange checker does state there is capacity.
26-05-2010 2:42 PM
Quote 21CN WBC status:
Not available
No your not on adsl2+.
looking at the recent history of vp capacity at your exchange it does not look good, there is away to find more history of your exchanges vp capacity but i forget the url for doing that ( hopefully jelv will see this and pass the url on as he has done a few times for me)
If your exchanges history of BT NOT sorting the pipes out when there running hot is real bad i would surrgest adding max preminum to your account which gives a contention ratio of 20:1 rather than 50:1 and also gives you a 832kbps upsync rather than 448kbps.
The only other way to avoid BT's hot 20cn VP pipes is to move to a LLU provider, But the exchanges that BT tend to let run hot are market 1 exchanges which tend not to have any llu providers on. Also if you had the option to move to adsl2+ 21cn then you could of also done that as the 20cn and 21cn pipes are diffrent
26-05-2010 3:55 PM
Notice how BT keep pushing back the fix date!
26-05-2010 6:43 PM
The joys of living in a village! No LLU and they don't bother fixing the bloomin' exchange.
27-05-2010 12:43 PM
If it doesn't sort it I guess I'll have to go back to value and put up with it until BT get their fingers out.
What does contention ratio mean?
27-05-2010 12:47 PM
On Max, IPStream Max Premium offers improved priority across the BT network.
27-05-2010 1:09 PM
The fact you can change products monthly is certainly a helpful feature, if it doesn't work I can always go back and wait for BT to sort their issues.
27-05-2010 5:28 PM
03-06-2010 1:29 PM
- Gaming
