Company of Heroes
- Gaming
- Company of Heroes
Company of Heroes
20-01-2013 5:19 PM
I am getting really frustrated now after phoning at least a dozen times about connection problems with a game Company of Heroes .. I have done everything that is needed to connect to the game, including port forwarding , the ports I added are as follows .. UDP 6112,30260,9100,9101,30275 .... I contacted THQ by phone and they say its nothing to do with their server, its the router and or configuration .. I am also very frustrated with the lack of support which Plusnet brags about on site and tv ...
All I get is excuses that Plusnet do not support the router configuration.. Why is that the case? as it is the equipment that Plusnet supply..
Any help in resolving my problem would be most appreciated..
6 REPLIES 6
Re: Company of Heroes
20-01-2013 5:30 PM
Can you got here and let me know what gateway you're on?
http://usertools.plus.net/@gateway
20-01-2013 5:33 PM
I am connected to the gateway known as ptn-ag01.
This is located in Telehouse North
20-01-2013 9:53 PM
Log into router and disconnect and then reconnect after a minute and check the gateway again, think they have been having issues with ptn-ag01 and ptn-ag02 the last 2/3 nights
20-01-2013 11:21 PM
The gateways we were originally seeing the issues on seemed to be pcl-ag01 and 2 but that wasn't actually the issue. Looking at the ping graphs, there hasn't be a recurrence since around 6pm.
20-01-2013 11:47 PM
sorry guys, must have got mixed up with pcl-ag01 / 2 and ptn-ag01 / 2 , think the eyes must be going, well it is getting late
21-01-2013 10:11 AM
1) Can we get this moved to Games forums please
2) mike180uk have you done a wireshark yet? This may help us work out if it's being prioritised properly. http://community.plus.net/library/faults/using-wireshark-for-data-capture/
Kelly Dorset
Ex-Broadband Service Manager
