CoD 4 Lag Spikes
- Gaming
- CoD 4 Lag Spikes
- « Previous
- Next »
Re: CoD 4 Lag Spikes
05-11-2009 1:59 PM
Were you seeing similar problems after doing a reboot?
General reports from last night suggest an improvement although it's not fixed yet.
05-11-2009 8:33 PM
05-11-2009 10:29 PM
06-11-2009 12:00 AM
This is my first post here but all I can say is... "Damn!"
I'm currently waiting to get connected to Plusnet PRO for £19.99 a month. The 100% reason I have just switched from O2 is because of Peak time gaming (they are terrible 200ms+ pings)
I was assured several times over the phone when registering that this won't be a problem with the PRO package, I hope the adviser (Hannah) has not fobbed me off in trying to get another customer.
I was paying £7.49 a month for O2s 8meg. (being on O2 mobile contract) I REALLY hope i've not made a mistake with Plusnet
damnit.
06-11-2009 1:56 AM
did you go for adsl2+ when you signed up?
i ask as there run over diffrent links this issue here is with the 20cn maxDSL.
am on 21cn adsl2 and have bein since the trial and currently the latency issue is this one at midnight for anything up till 1-2am. but during peak time latency is fine on 21cn adsl2+.
http://community.plus.net/forum/index.php/topic,80166.0.html
welcome to PN and the forum and am sure reading about and seeing the staff so active on the forum will be a huge diffrence from your last isp
06-11-2009 12:52 PM
I have noticed the staff are pretty active on these forums which is a good sign already. Will just have to wait and see I suppose
Andy.
Re:CoD 4 Lag Spikes
06-11-2009 1:51 PM
It's actually not as bad as you might think. The last reply you had, which whilst you would have no way of knowing, was confirmation that it was being fixed and should be done so with our next batches of game fixes, which we do weekly.
Re:CoD 4 Lag Spikes
06-11-2009 3:33 PM
Quote from: Jameseh Hiya,
Thank you James, hopefully we will see an end to it and I can get back to pwning noobs!
06-11-2009 10:30 PM
Most annoying thing is the inconsistency. I can start a game with good ping then it peaks and drops right through - very hard to get your eye in.
06-11-2009 11:39 PM
icmp pings are fine to bbc thoe just checked
10-11-2009 4:20 PM
Would just like to say I am in exactly the same position. Been with plusnet since october 2008 on the Option 2 Broadband your way. Up until last a month ago my broadband has been superb, no dropouts, no high pings, 6-7mbps speeds. But this last month, the service has been dreadful. I have posted a ticket to the support and I keep on going around in circles. They keep on sending me the 'We can escalate to Bt but will cost £169 if an engineer finds no fault' nonsense. I am away at sea until thurs so will check it out again. Anyway, no matter what part of the day I do a speed check, the ping is always around 150 - 170 and speed can be anything from nothing up to about 3mbps. On the speedtest.net check the needle starts raising on the download test but then stops and stutters and it takes forever to do the download test. I guess the connection must be dropping at these moments!! Anyway hope Plusnet will get it sorted otherwise I'm going to have to move provider as Cod4 part 2 is out and I NEED a good connection!
- « Previous
- Next »
