Choke on all steam games since switched to PlusNet Unlimited
dougieskins
I've recently switched from the PlusNet Value to the unlimited service, and on all steam games (like counter-strike:source, day of defeat source, left 4 dead) I am getting an absolutely HUGE amount of choke, making them completely unplayable, which I didn't get AT ALL before.
This is very strange seeing as
Plusnet Value is ideal for web surfing and email. It is not suitable for frequent gaming, binary USENET, Peer-to-Peer, VPN, FTP or lots of music and video downloads.
yet,
Plusnet Unlimited is designed for serious Internet users and is ideal for all Internet activities.
I have raised a ticket on the website which was absolutely USELESS, not only does it take ages, they said there was nothing wrong according to the wireshark capture I did. To be fair, my ping is fine, although a little higher than before, but it is just the huge choke thats the problem.
Please can someone help me, its driving me insane!
28 REPLIES 28
Fixes: 1,483
Re: Choke on all steam games since switched to PlusNet Unlimited
Try doing a wireshark capture to make sure it is been prioritized correctly.
Is your connection ok for browsing etc?
dougieskins
Re-read what I said, I've already done a wireshark capture and according to the network team it is being prioritised correctly. Browser speeds/ download speeds and everything else are absolutely fine (well as fine as you can get when you only get 1.5mbps from a possible 8 :(..).
Fixes: 1,483
Oops, sorry about that..
Does your exchange so any issues here http://usertools.plus.net/exchanges/
Have you ever had interleaving switched off?
What are your line stats?
dougieskins
Nope my exchange, which is Frensham, has absolutely no problems.
Sorry I am an absolute nub, what is interleaving? And how do I get my line stats?
Oldjim
Resting Legend
Fixes: 63
scootie
and this for interleaving info. for gaming you realy want to be on fastpath (interleaving off)
http://www.kitz.co.uk/adsl/interleaving.htm
dougieskins
Thanks.
These are my line stats:
As for the interleaving, how do I tell if it is on or off?
I doubt it will be on because I have never requested it.
dougieskins
Please don't give up on me yet, i've been trying to sort this out for weeks!
Euge
Interleaving is, in most cases, set to on automatically. It's there to stabalise your line and is provided by BT. Turning on fast path is requested via plusnet and then onto BT.
See here for the interleaving off option. Go to the bottom of the page titled interleaving and use the help assisstant highlighted.
Im not sure about other people's routers, it probably varies, but go to the address of your router which is usually 192.168.1.1 via your internet explorer. But can be 192.168.1.0 I believe.
For instance I can get this info
Line Mode G.DMT   Line State Show Time
Latency Type Fast  Line Up Time 00:13:27:29
Line Coding Trellis On  Line Up Count 1
Statistics Downstream Upstream
Line Rate 5024 Kbps 448 Kbps
Noise Margin 8.3 dB 20.0 dB
Line Attenuation 47.0 dB 24.5 dB
Output Power 19.8 dBm 11.8 dBm
Latency is type fast which means fast path, but in your case it might say interleaved.
Oldjim
Resting Legend
Fixes: 63
Can you do a tracert to plus.net
You need to open a DOS window - and then type tracert plus.net
Euge
And just in case you don't know, you can do that by going into start ---> run and typing cmd and press enter  Smiley
dougieskins
Ha ha kk thanks. So I've done this but no idea what the results mean:
Euge
whats it says is that you could do with getting those pings down a bit. Those are the kind of numbers I was getting with interleaving and now without it those figures are between 17 and 30ms
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\Administrator>tracert plus.net
Tracing route to plus.net [212.159.8.2]
over a maximum of 30 hops:
  1    1 ms    1 ms    2 ms  voyager.home [192.168.1.1]
  2    52 ms    20 ms    18 ms  lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
  3    17 ms    16 ms    17 ms  ge0-0-0-303.ptn-gw01.plus.net [84.92.3.9]
  4    18 ms    18 ms    18 ms  gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
  5    26 ms    25 ms    25 ms  pos1-0.pih-cr1.plus.net [195.166.129.250]
  6    26 ms    26 ms    26 ms  vlan7.pih-gw3.plus.net [212.159.0.26]
  7    26 ms    24 ms    26 ms  if25.pih-lb04.plus.net [212.159.0.18]
  8    26 ms    25 ms    26 ms  www.plus.net [212.159.8.2]
Trace complete.
  1    1 ms    1 ms    1 ms  voyager.home [192.168.1.1]
  2    17 ms    17 ms    18 ms  lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
  3    20 ms    20 ms    18 ms  ge0-0-0-303.ptn-gw01.plus.net [84.92.3.9]
  4    19 ms    19 ms    17 ms  gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
  5    26 ms    26 ms    27 ms  pos1-0.pih-cr1.plus.net [195.166.129.250]
  6    25 ms    26 ms    27 ms  vlan7.pih-gw3.plus.net [212.159.0.26]
  7    26 ms    25 ms    26 ms  if25.pih-lb04.plus.net [212.159.0.18]
  8    27 ms    29 ms    30 ms  www.plus.net [212.159.8.2]
Trace complete.
the 52 was a blip  Grin
dougieskins
Right, so shall I request for plus net to turn interleaving off then? And thank you very much Euge you have been, by far, the most help I've gotten from anyone, including the plus net customer service and network team!
