Chane NAT type to open
- Gaming
- Chane NAT type to open
30-03-2016 10:35 PM
i have a moderate nat type i was wondering how i would be able to change this to open?
adie:red changed all caps title as per link:rules ]
1 REPLY 1
Re: Chane NAT type to open
30-03-2016 11:59 PM
Hi Chris welcome to the forums. In the first instance you will need to go into your router settings and do port forwarding, go to the link i added below it will tell you what ports to forward and how to do it, if you play black ops 3 you will also need to forward port 3075 UDP
https://community.plus.net/forum/index.php/topic,147977.0.html
