Cant play online on my PS3
- Gaming
- Cant play online on my PS3
26-03-2016 7:22 PM
hi
I am trying to play online GTA 5 on my PS3 and I cant join an online session. i have been online using the same connection, I did some searching on the rockstar forums and found that it might the nat type . it is recommended that the NAT type should be open. the router i have has been set to moderate which I found out when I was playing black ops.
how do I change the nat type. I know it has something to do with DMZ on the router settings its says i need to assign it to the device.
how can I play online on GTA 5 because it cant even go on to the session
thanks
thanks
4 REPLIES 4
Re: Cant play online on my PS3
26-03-2016 8:11 PM
Hi to get your nat open you need to forward ports in your router settings, go to this link it tells you how to forward ports. http://community.plus.net/forum/index.php/topic,147977.0.html
How much this will help with GTA 5 I don't know as this is an issue rockstar know about but don't fix. But I would try and forward your ports first see if that helps.
26-03-2016 10:36 PM
thanks for the reply and i will check it out
26-03-2016 10:41 PM
No problem, good luck and welcome to the forums
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
27-03-2016 11:39 PM
Hey aslam did that get your nat open?
