Can you add Fifa 10 to the defined list please
goberpiles
Few different ports for Fifa 10 in manual:
TCP: 80, 443, 9980-9989, 14500-14559, 42100
UDP: 9570, 3659, 6000
8 REPLIES 8
Fixes: 1,483
Re: Can you add Fifa 10 to the defined list please
You'll probably need to add a wireshark capture to a ticket too to enable to sig to be created properly.
James
I'd be very surprised if it wasn't in there already.
Chris
Legend
Fixes: 169
Looking at the already defined rules we've got most of those ports set up for FIFA 09, the only difference appears to be FIFA 10 is using 14500-14559 and FIFA 09 uses 12400-12499. If you raise a ticket with a wireshark capture whilst your gaming we'll make sure everything is defined as it should be.
ITFCdan
Quote from: adiewoo
I did 3 days ago Sad
goberpiles
I as under the impression that I could not run wireshark to capture a game being played on the PS3?
bobpullen
Fixes: 316
Quote from: ITFCdan
Quote from: adiewoo
We'll take a look tomorrow and see if there's anything we need to add to this week's Ellacoya traffic management additions.
scootie
Quote from: goberpiles
you can and i do for my xbox from time to time.
basicaly you need to hook your console up to your pc and set it up so that the console uses the pc's internet connection and wireshark will see the traffic passing through as normal
google internet connection sharing (ICS) or bridging ( is what i use as i had trouble not being able to port forward with ics)
i use my laptop's wireless connection for doing this as i dont actualy play games with this set up just use it for the wireshark capture
goberpiles
Might be able to use my laptop then by the sounds of it, this is the major problem I am having: http://community.plus.net/forum/index.php/topic,79949.0.html
