COD 4 - odd popup
Oldjim
Fixes: 63
COD 4 - odd popup
I keep getting this popup when COD 4 single player starts - any idea what is causing it and could it fall foul of the DRM system
3 REPLIES 3
Oldjim
Fixes: 63
Re: COD 4 - odd popup
Should have googled before posting - it is a common problem and may be due to running Vista
meatloaf
if you havent already run game as admnistrator  that might help
Chris
Legend
Fixes: 169
I get the same regularly on XP, it happens on COD:WaW too. I've never actually looked into it so not sure what's causing the problem.
