Broardband Pro
- Gaming
- Broardband Pro
Broardband Pro
08-01-2009 4:10 PM
I mainly use bb to play online ( pinging high teens to high twenties depending on game and server) and watching the odd programme on iplayer. I have been looking at my recent usage and normally stay under 15Gb. If I need to buy more how much is it?
Also if I do upgrade will it have any effect on my phone package?
Look forward to any advice and thanks in advance.
Rob
Re: Broardband Pro
08-01-2009 4:21 PM
I'm not sure if you are aware, but moving to Pro will not improve your overall speed.
It just means that all traffic is prioritsed at a high level, meaning that your games should always get good pings through our network (even if we're not treating them in the right way) and that P2P and Usenet traffic will run at quick speeds throughout the day.
Re: Broardband Pro
08-01-2009 4:36 PM
Thanks for the quick reply.
I was not expecting a gain in my pings as I am hardly ever beaten for speed when i look.
What I was wondering about is the iplayer as at the mo it tends to hang a fair bit.
Also I am right in assumming that e-mail stays the same as I noticed on 3 I have unlimited accounts (I only have 4 ) but there is no mention of this in the Pro blurb?
Rob
Re: Broardband Pro
08-01-2009 4:41 PM
All the additional features (like email) are the same across our residential product range. You would be welcome to try out Pro for a month to see if it improves your iPlayer traffic and I can always move you back if it's not helped out at all.
I personally wouldn't have expected it to make a massive amount of difference as streaming should be treated the same way on Option 3 and Pro.
Re: Broardband Pro
08-01-2009 4:47 PM
If it is possible to try for a month or 2 how do I go about then?
Rob
Re: Broardband Pro
09-01-2009 1:10 PM
When it says gaming traffic is prioritised, I'm sure i've seen a comparison chart somewhere that says all packages have gaming priorised. Am I wrong in that, or is there something else that sets the gaming traffic different accross the packages?
Re: Broardband Pro
09-01-2009 1:20 PM
The main difference is how advanced protocols are prioritised.
The benefit to gamers is that should a new game come out and we're not prioritising the traffic properly, the gaming speeds will still be good.
Re: Broardband Pro
09-01-2009 2:59 PM
I assume that shouldn't be too much of an issue for console games though using the same PSN or XBL.
Re: Broardband Pro
09-01-2009 4:31 PM
It seems he doesn't need much of an excuse to pick up some new games for his PS3
Re: Broardband Pro
26-01-2009 10:56 PM
I just migrated over from supanet onto the pro package in the hope of lag free evening gaming.
Having read most of the posts on this front page of the "gamers forum" i'm glad to see nobody moaning about lag too much, fingers crossed.
MY results with supanet were OFF PEAK down 5750 up 400 kbps ping 55
PEAK down 1000 up 300 kbps ping 200+
It was horrible for COD4/5 on PS3
I should be online next monday.
Re: Broardband Pro
27-01-2009 5:04 PM
Re: Broardband Pro
27-01-2009 5:07 PM
If your speeds were as a result of the Supanet network, then I suspect that you will definitely see improved speeds once you've moved over to us
Re: Broardband Pro
27-01-2009 5:12 PM
I don't know what else it could be other than PUPANET , I hope at least my ping improves , my gaming life depends on it!!!
Re: Broardband Pro
27-01-2009 5:14 PM
Either way, I'll happily have a look when you come over
Re: Broardband Pro
27-01-2009 5:31 PM
I'm sure they do use interleaving, do plusnet use fast then?
