Battlefield 2142 ping (pc)
- Gaming
- Battlefield 2142 ping (pc)
20-01-2009 2:22 AM
Re: Battlefield 2142 ping (pc)
20-01-2009 9:16 AM
When you do a normal ping via a command prompt, does it also show poor latency at the same time?
20-01-2009 9:30 AM
20-01-2009 12:18 PM
James my friend said he thought it could be something to do with latency,if it is what should i do?
Chris can you try a server called ukce 24/7 please its just for a test,i get a ping of 20-30.
20-01-2009 12:59 PM
Latency is ping (the amount of time it takes for a packet of data to get there and back) - sorry if I'm teaching you to suck eggs!
It'll be interesting to see how Chris' testing goes.
20-01-2009 1:00 PM
21-01-2009 8:39 AM
21-01-2009 8:17 PM
22-01-2009 11:22 AM
Have you specified the MTU on your PC aswell as on the router? If not, it can't hurt to try. I'd keep it the same on both your PC and the router.
23-01-2009 1:00 PM
24-01-2009 9:34 PM
26-01-2009 12:09 PM
Glad to hear it.
