'BBYW Option 3' v 'Broadband Your Way Pro' For XBox Live Gaming
- Gaming
- Re: 'BBYW Option 3' v 'Broadband Your Way Pro' For...
03-11-2008 11:15 AM
Only doing gaming with Xbox Live. No PC games.
So would 'BBYW Option 3' give equal performance when compared with 'Broadband Your Way Pro' when using XBox live ?
5 REPLIES 5
Re: 'BBYW Option 3' v 'Broadband Your Way Pro' For XBox Live Gaming
03-11-2008 11:40 AM
Hiya Tbird,
XBL generally uses the same signatures for most of it's gaming traffic as far as I know, so BBYW3 should be perfectly ample for your needs.
03-11-2008 11:40 AM
Just to add on, all our BBYW packages are on monthly contracts, so you could always try out Pro for a month if you wanted to make sure.
03-11-2008 11:46 AM
Quote from: Jameseh Just to add on, all our BBYW packages are on monthly contracts, so you could always try out Pro for a month if you wanted to make sure.
Thanks. Just moved to PlusNet last week and started with Pro but I think I'll not be long in hitting the 15Gb limit so thinking of moving to BBYW 30gb - which'll be a no-brainer really if the XBL performance will be the same, mainly for Halo 3 multiplayer. (Not that I'm any good at Halo 3 it's the reverse to be honest as I'm pretty crap at it and need every advantage I can get ;D)
03-11-2008 11:48 AM
I'm pretty rubbish at Halo 3 too
But then I'm rubbish at pretty much every FPS so that's not a massive surprise.
03-11-2008 6:35 PM
XBL is perfect on option 3. i have no problems at all with racing games which are pretty sensitive to any ping spikes.
- Gaming
