Any ideas on whats the best monitor ?
- Gaming
- Re: Any ideas on whats the best monitor ?
27-12-2016 11:34 AM - edited 27-12-2016 11:57 AM
27-12-2016 12:02 PM - edited 27-12-2016 12:05 PM
I can't help with respect to a monitor in that price range as a full IPS is almost certainly too expensive but I can definitely recommend buying from Amazon because of their no quibble return policy (other retailers won't accept a return because of a couple of stuck pixels)
Another thought - how about a 27" which is just inside your price range
27-12-2016 12:11 PM - edited 27-12-2016 12:12 PM
Naa has to be 24 because of the desktop space ive got.
27-12-2016 12:49 PM - edited 27-12-2016 12:57 PM
If you can afford one get a 1920X1200 display rather than the 1920X1080.
The extra (120 pixels 11%) screen real estate doesn't sound much but I find it makes a big difference to the usefulness of the display when looking at websites or reading text. The extra lines you get make the scrolling far less intrusive.
Amazon have a refurbished HP A9P21AT or a new Acer G7 G247HYLbidx at about your price point.
28-12-2016 2:49 PM
heres a selection of 1ms response time hdmi/dvi/vga monitors http://www.ebuyer.com/store/Computer/cat/Monitors/subcat/24%22-Monitors?a02318=1&q=24%22+monitor&sor...
some of them are cheaper some are more expensive.
heres a selection of similar units from amazon https://www.amazon.co.uk/s/ref=sr_st_price-asc-rank?keywords=24%22+hdmi+monitor&fst=as%3Aoff&rh=n%3A...
which one is best is rather subjective i'd personally be inclined to get a Samsung iiyama acer or aoc monitor but only because historically they used better grade screen panels (which probably isn't the case anymore) although if your getting something to link with a high end graphics card for gaming then it might be better to go with a g-sync /freesync monitor (depending on what gfx card you went for)
i upgraded my iiyama monitor to a freesync one and freesync made a difference to my eyes at least (but then i'm too cheap to pay out more than £200 on a gfx card)
30-12-2016 11:49 AM
Just upgraded one of my desktops with 2 x 2 array of http://www.pcworld.co.uk/gbuk/computing/pc-monitors/pc-monitors/acer-s241hlcbid-full-hd-24-led-monit...
05-01-2017 4:53 PM
Nice price
07-01-2017 2:57 PM
This used to be the case, but if you buy anywhere online you have the right to return an item, as long as it has only been "inspected" in a way you could do in a shop, e.g. you can open the box, plug in a monitor. If its got a dead pixel you dont return for it being faulty - because it isnt - but return under distance selling regulation that you have changed you mind now you have seen it.
Not so clear on who pays postage back, some will pay for you others state you pay.
Id agree though Amazon is usually amongst the cheapest and their returns is certainly very hassle free!
I got this when it was about £500, seems to have gone up in price though - BenQ BL3201PT - awesome 4k monitor. games look great but will only to 60hz
03-03-2017 1:00 PM
I had good experience with Samsung monitors with 1000ms.
Currently I have this one and it's amazing!! https://www.amazon.co.uk/Samsung-U28E590D-28-Inch-Monitor-3840/dp/B00WUACE4S/
Cheers
31-03-2017 12:31 PM
is anyone using a G-Sync monitor ?
31-03-2017 9:45 PM
given the price of g-sync monitors that's doubtful...
NVidia really screwed up their pricing for the g-sync licence as if their gfx cards weren't over priced already they had to try and milk the consumer from both sides....
freesync though is much cheaper to licence and the compatible cards are normally half the price of comparable NVidia ones /
01-04-2017 6:58 AM
yes Ste , i have a ROG swift PG278Q and can honestly say you can hardly notice a difference
It is better but is it worth the extra cost
