Adding game to defined list ?
- Gaming
- Adding game to defined list ?
06-06-2012 6:41 PM
Just arrived at Plusnet, complete with the Pro add on.
How do I add a game to the defined list and what information is required ?
3 REPLIES 3
Re: Adding game to defined list ?
06-06-2012 7:20 PM
Hi Damocles, welcome to the forums.
Can you let us know what platform and game this is on?
We need as much info as you are aware of about the game, such as the ports it uses for service, such as the games website and such.
We will also need a Wireshark capture of the game, though we know this is not always possible depending on the platform and your network setup. Instructions to use this can be found on the following page. Please ensure that you start Wireshark and its capture function before you even launch the game (that includes entry to the games lobby).
http://community.plus.net/library/faults/using-wireshark-for-data-capture/
06-06-2012 8:39 PM
Thanks for quick reply.
My graphics card is a bit long in the tooth at the moment, but hopefully the Postie will be delivering a new, all singing, all dancing one in the next few days (depending on availability :(). Is it worth waiting until I've installed the new card before I do a Wireshark capture ?
Cheers Tom
Cheers Tom
06-06-2012 10:21 PM
With pro addon there is no traffic management that should affect any online game. But if you ever get it taken off and notice a game is lagging, then you need to supply a wireshark capture while in the game running.
FTTP 500 regrade from Tues 28th November
