AS6453.net peering sucks
- Gaming
- AS6453.net peering sucks
Re: AS6453.net peering sucks
18-03-2014 5:18 AM
But think broadband's routing seems to be better than the current way I'm routed to it,
18-03-2014 8:42 AM
My routing is no longer going via Level3/Tinet Paris:
TRACEROUTE (using port 3077/tcp)
HOP RTT ADDRESS
1 1.27 ms router.asus.com (192.168.1.1)
2 5.77 ms lo0-central10.pcl-ag06.plus.net (195.166.128.187)
3 5.47 ms link-a-central10.pcl-gw01.plus.net (212.159.2.180)
4 5.16 ms xe-10-3-0.pcl-cr01.plus.net (212.159.0.212)
5 5.28 ms xe-11-2-0.edge3.London2.Level3.net (212.187.201.213)
6 5.54 ms vl-3101-ve-127.ebr1.London2.Level3.net (4.69.202.169)
7 5.44 ms ae-48-48.ebr1.London15.Level3.net (4.69.159.78)
8 5.25 ms ae-43-43.ebr1.London1.Level3.net (4.69.167.26)
9 4.93 ms ae-56-111.csw1.London1.Level3.net (4.69.153.114)
10 4.59 ms ae-117-3503.edge3.London1.Level3.net (4.69.166.138)
11 4.41 ms ix-20-0.tcore1.LDN-London.as6453.net (195.219.83.101)
12 97.33 ms if-17-2.tcore1.L78-London.as6453.net (80.231.130.129)
13 98.91 ms if-2-2.tcore2.L78-London.as6453.net (80.231.131.1)
14 98.10 ms if-20-2.tcore2.NYY-New-York.as6453.net (216.6.99.13)
15 98.57 ms if-12-6.tcore1.CT8-Chicago.as6453.net (216.6.99.46)
16 101.42 ms if-22-2.tcore2.CT8-Chicago.as6453.net (64.86.79.1)
17 97.62 ms if-3-2.tcore1.W6C-Montreal.as6453.net (66.198.96.45)
18 116.88 ms 66.198.96.18
19 97.30 ms msr-onl-fw01.ubisoft.com (216.98.51.10)
20 99.94 ms lb-lsg-prod.ubisoft.com (216.98.48.56)
18-03-2014 2:01 PM
Currently it is giving pings of 95-99ms but it may starts to flap when traffic levels become higher because that tinet link when i ping the ubi/tinet gateway , is the weak link , you can see the jitter in the ttbqm
http://www.thinkbroadband.com/ping/share-large/eb805a63b74a844e58607bac76faae5f-18-03-2014.png No change in latency over AS6453.net again the hop before ubisoft
Target Name: lb-lsg-prod.ubisoft.comNo improvement Apart from the peak time type latency hump between 2 and 4am missing , which is when i tend to play this game but something was getting switched around by someone, or something was failing , it did show a little increase in bases latency at the time of those red spike, though ping plotter doesn't show the red spikes
IP: 216.98.48.56
Date/Time: 18/03/2014 13:12:20 to 18/03/2014 13:54:42
Hop Sent Err PL% Min Max Avg Host Name / [IP]
1 998 0 0.0 0 0 0 home.gateway.home.gateway [192.168.1.254]
2 998 0 0.0 13 738 24 lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3 998 0 0.0 13 106 13 link-a-central10.ptw-gw01.plus.net [212.159.2.144]
4 998 2 0.2 13 87 13 xe-4-2-0.ptw-cr01.plus.net [212.159.0.240]
5 52 1 1.9 14 317 71 te-4-2.car5.London1.Level3.net [217.163.45.249]
6 998 0 0.0 13 24 13 ae-52-52.csw2.London1.Level3.net [4.69.139.120]
7 30 0 0.0 13 17 14 ae-228-3604.edge3.London1.Level3.net [4.69.166.158]
8 998 0 0.0 13 43 13 ix-20-0.tcore1.LDN-London.as6453.net [195.219.83.101]
9 998 65 6.5 106 119 107 if-17-2.tcore1.L78-London.as6453.net [80.231.130.129]
10 998 15 1.5 106 122 107 if-2-2.tcore2.L78-London.as6453.net [80.231.131.1]
11 998 99 9.9 107 168 111 if-20-2.tcore2.NYY-New-York.as6453.net [216.6.99.13]
12 998 12 1.2 105 118 108 if-12-6.tcore1.CT8-Chicago.as6453.net [216.6.99.46]
13 998 12 1.2 105 126 108 if-22-2.tcore2.CT8-Chicago.as6453.net [64.86.79.1]
14 998 0 0.0 105 128 108 if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
15 98 0 0.0 105 199 109 [66.198.96.18]
16 98 0 0.0 105 110 107 msr-onl-fw01.ubisoft.com [216.98.51.10]
17 995 958 96.3 107 1487 362 lb-lsg-prod.ubisoft.com [216.98.48.56]
We can compare routes allday, but it is not going to restore the lower ping that i had or stop gaming traffic getting routed over some links that are at capacity or touted around the planet
It has been 3days today , sinve ubi's ddos scrubbing nonsense (which was probably down to the large number of BT retail customers all doing tracerts and pinging their server in the first place) Because Ubi are clueless , and nothing further from plusnet , any thing further on this ?
18-03-2014 3:19 PM
We've not made any changes on our side. We're waiting for the Ubisoft/Verisign link to come up (it doesn't seem to be set up at their end yet) and our traffic should route over that link directly.
Matt
18-03-2014 5:01 PM
this scrubbing was switched off on sat/sun therefore the threat( False/alarm positive) is over and normal operation resumed there is no way on this planet that ubisoft is going to fund DDOS scrubbing costs over a long period of time ,So what's stopping you making the changes, make them now and traffic should continue to take the same path should they decide to implement this scubbing bs again in the future
Also who is to say that if they did use a 3rd peering transit provider( Verisign) that this would improve on what i have now? if the past few day where anything to go by It wont give lower latency,Currently Tinet is the one that is offering lower latency Sub 100ms
18-03-2014 5:07 PM
Quote from: deathtrap ....make them now and traffic should continue to take the same path should they decide to implement this scubbing bs again in the future....
Hi
Even if we do make any changes it won't prevent traffic being routed via a DDoS mitigation platform if thats the only place they announce their prefixes from to the wider world.
18-03-2014 5:16 PM
18-03-2014 5:22 PM
Is it fair to assume that the latency for an end user would be roughly an additional 5-15ms (if they are on fibre) over what the latency is from the Looking Glass results?
Also, is there any way to see what changed (if it was the routing) last night in those TBB Ping Graphs that has lowered the latency 12-15ms? Or is it only TBB that will be able to see a change in a route etc?
18-03-2014 5:34 PM
The tinet latency isn't too bad, aprox 80ms to tbb from Montreal where as the AS6453.net tbbqm show 100ms aprox base latency, this used to be a max of 80ms until someone started routing via Chicago
18-03-2014 6:41 PM
19-03-2014 8:47 AM
TBB's traceroutes go to above.net and then tinet - I had this confirmed from them:
Quote show route protocol bgp table inet.0 216.98.54.42 terse
inet.0: 490527 destinations, 3377545 routes (489350 active, 78 holddown, 8048 hidden)
Restart Complete
+ = Active Route, - = Last Active, * = Both
A Destination P Prf Metric 1 Metric 2 Next hop AS path
* 216.98.48.0/20 B 170 100 4294967294 >141.136.100.29 3257 22634 I
B 170 100 4294967294 >195.66.224.51 6453 22634 I
B 170 100 4294967294 64.125.27.149 6453 22634 I
>64.125.27.149
64.125.27.149
64.125.27.162
64.125.27.162
64.125.27.162
B 170 100 4294967294 >64.125.27.149 6453 22634 I
64.125.27.162
>64.125.27.149
64.125.27.174
64.125.27.174
64.125.27.174
>64.125.27.149
64.125.28.97
64.125.28.97
Level3
Quote BGP routing table entry for 216.98.48.0/20
Paths: (2 available, best #1)
6453 22634
AS-path translation: { GLOBEINTERNET AS22634 }
edge3.London1 (metric 20020)
Origin IGP, metric 100000, localpref 86, valid, internal, best
Community: Europe Lclprf_86 United_Kingdom Level3_Peer London Level3:11078 6453:1000 6453:1100 6453:1106
Originator: edge3.London1
6453 22634
Paths: (2 available, best #2)
6453 22634
edge3.London1 (metric 41240)
6453 22634
AS6453/Tata
Bestpath Modifiers: deterministic-med
Paths: (3 available, best #3)
Multipath: eBGP
17 18 19 20
22634
w6c-tcore1. (metric 3089) from l78-tcore1. (66.110.10.237)
Origin IGP, valid, internal
Community:
Originator: 66.110.10.134
22634
w6c-tcore1. (metric 3089) from l78-tcore2. (66.110.10.234)
Community:
22634
w6c-tcore1. (metric 3089) from ldn-tcore2. (66.110.10.39)
Origin IGP, valid, internal, best
Community:
19-03-2014 9:04 AM
either way it shouldn't be having any impact on latency
this was one such example
IMO i have shown that there is quite possibly an issue with AS6453,net Peering to Montreal (ubisoft ) that has gotten a lot worse since they changed the routing to go via Chicago
I notice that Goscomb appear not to use AS6453.net and they peer through level3 to tinet http://as39326.net/lg/klg.php?server=collector&action=show+ip+bgp&args=216.98.48.56
Just an observation , So can routing via tinet be tried or is this not going to happen despite being told a short time ago it was going to be tried ?
19-03-2014 9:35 AM
Quote from: deathtrap I notice that Goscomb appear not to use AS6453.net and they peer through level3 to tinet http://as39326.net/lg/klg.php?server=collector&action=show+ip+bgp&args=216.98.48.56
I think they peer with GBLX/Level3 - which seems to be different:
Quote 3257 22634
67.16.147.121 from err41.cdg2.gblx.mgmt.level3.net
Origin IGP, metric 50, localpref 200, valid, internal, best
Community: 3549:2203 3549:2623 3549:30840 (North American; United States) 3549:31250 (Europe; France)
Originator: loop0.ar3.CDG2.gblx.net, Cluster list: 0.0.6.3
19-03-2014 10:14 AM
19-03-2014 4:56 PM
