AA Punkbuster blues
- Gaming
- AA Punkbuster blues
AA Punkbuster blues
17-09-2007 6:57 PM
Hi Folks
I am having a punkbuster problem in Americas Army, about 90% of the time I am getting kicked by punkbuster for an 'unspecified reason' I am using the latest version of both AA and Punkbuster. Anyone seen this before?
5 REPLIES 5
Re: AA Punkbuster blues
17-09-2007 8:07 PM
Maybe something running on your PC that it doesn't like.
Go through your running processes and get it running as clean as poss' then try again.
Perhaps clearing the "prefetch" folder in windows may help - incase an earlier version of Punkbuster or whatever is causing probs.
17-09-2007 8:22 PM
Services: PnkBstrA.exe is running but not PnkBstrB Do they both need to run?
17-09-2007 8:34 PM
I may have solved it, it seems under vista when you boot AA the PnkBstrA service doesnt start as it is in manual mode. having started it my first connect was ok, I will report later if it stays fixed 😉
18-09-2007 2:32 PM
Great glad you resolved it
................. Now wheres that world peace?
18-09-2007 3:28 PM
Manually starting the 'A' service seems to boot the 'B' service as well. I am not convinced that AA is as Vista friendly as it could be. But it is free, so I can't really complain too much!
