xbox live question... yes.. another one!
We had a major problem with our PC and as a result had to get a new motherboard, processor and new hard drive...... now when we turn on the pc and the xbox it says the connection isnt working.
May be a silly question.. but will having made all the changes to the pc we have made a difference to the way the xbox live needs to be set up?
Im not sure about things like IP addresses... will we now have a new one and is that why it wont connectHuh
Any advice would be great.. thanks Smiley
How do you set up xbox live againHuh Router or ics Huh
i have an ethernet card in the pc so i use that and a crossover cable direct to the xbox.
jberry
I would start afresh and set up ICS from scratch again, exactly like you did before. The change of network card will be a definate problem as the MAC address will have changed.
Regards,
thanks we deleted the netwrk it was using. made a new connection and its working fine Smiley
thanks for your help
