xbox & keyboard/mouse play
Delves
Post your gametags.
The Xbox was a level playing field till these were added. I'll make sure I'm not in a game with a keyboard/mouse player.
Consoles use a pad and a PC uses a mouse keyboard and thats the way it should stay.
I read somewhere that you can buy a convertor to allow you to play games on the xbox using the keyboard and mouse combination as in most PC games.
i was wondering if anyone else has heard of this or tried it... and if anyone has any idea where you can buy them!!!
I like shooting games and do like the X-Box but after years of playing PC games i cant get used to using the controllers for the Xbox and always end up shooting the ground or the ceiling!!!!
Hi Lisa,
Do you mean something like this?
http://xbox.gamespy.com/articles/565/565000p1.html
I've seen some montages of several of the worlds top ranked Halo 2 players and I reckon some of them must be using a mouse / keyboard combo to be able to accurately shoot like that, particularly when using the sniper.
oooh thanks for that.. i now need to find somewhere over here that sells them... im getting way over excited here!!! :shock: Tongue :shock:
oooh.. my beloved Ebay has come up trumps!!!! I can get ne on Buy It Now for £19.99 with £4 p&p.... will have to wait til after the move but im well chuffed!!! many thanks for reminding me of what they were called Smiley
Smiley
I have a smart frag. It is easy to set up, just remember to edit the blank profile then assign it, rather than trying to edit a predefined setting.
Whilst it is a little easier to play Halo2, I still suck at it. I'm using a microsoft intellimouse which has 5 buttons + wheel scroll down/up which are all definable.
One thing I do miss from Quake2 etc is the side step move which isn't in Halo 2.
I would definatley play around with the Halo 2 settings for the speed of the look/turn movement as you'll still need to adjust this for the mouse control. If I had done this in the first place, I might have persevered with the controller a bit longer.
Rather than ebay try liksang for a smart frag they import from HK and are pretty cheap even if you get stung with custom fees.
http://www.lik-sang.com/list.php?category=160&lsaid=394890
George
http://www.comicmarketplace.co.uk
thanks for that.. i did see that sight but i dont have a debit or credit card to pay for it via the net Sad
glad they seem to work tho! after our house move and baby is born i shall be looking to invest in one! Smiley
