wolfenstein: enemy territory server problems
I tried to connect to either of the Wolfenstein: Enemy Territory Servers,
Castle Wolfenstein Enemy Territory: Campaign - 212.159.6.195:27960
Standard Mapcycle : 20 Player : Running Punkbuster
Castle Wolfenstein Enemy Territory: ETPro - 212.159.6.212:27960
7 Map Campaign Cycle : 18 Player : Running Punkbuster and ETPro mod
but I get this message saying punkbuster server running old version and then after a short while it disconnects me. Is there a solution for me? Or does the Server need updating?
In the second server something weird happens. When I get in a tank it zooms across the map. Or water pumps instantly get rid of the water. Is this due to server settings?
jberry
Punkbuster should update itself, if you have a look at this page on the punkbuster website it tell you how to make sure your own version of punkbuster is up to date. I will also have a look at the servers myself when I get a minute but no-one else has mentioned this to me.
Not sure on the second one, it may be the way that the ETPro mod works. I'll ask the guy that admins it.
Later,
Hmm the second one works now, apparently it was something to do with the speed settings.
My version of punkbuster is up to date but the message still appears.
jberry
The reason for the weirdness is that the admins were messing around and forgot to change the settings back. The cvar changes, just in case you want to know, were:
b_moverscale 1.0 if the corect setting
anything above 1.0 makes things move faster
b_moverscale 50 gives a turbotank
also
b_moverscale 0.1 makes the tank hardly move at all
g_speed 600 makes all the players run very fasy
g_gravity 100 is also funny (normal is 800)
Regards,
