unable to connect to WAN on new router
Hi
Just aquired a router & I am having problems with WAN connections
I have a plus account , therfore a dynamic ip address & not static .
I am unsure if I am using correct settings :-
Have posted screen shots to help
Please help !
Cheers
On the first screenshot, the value in the "virtual circuit identifier" box should be 38, not 30
Also on the first screen shot, what other options are there under the "encapsulation" drop down box?
In the second screen shot, where you have the dropdown box for operating mode "ansi-dmt", what other options are there?
I would try changing the Virtual Circuit Identification number to 38 firstly. If that doesnt work, try and post back with the other information I asked for.
Edit: Nice piece of kit by the way Wink
dontfollowme
Tried using the format: username@plus.net
Just a suggestion
