streaming music from PC to 360
Hi does streaming music from your PC to your Xbox 360 over wireless count towards monthly usage? Thanks
As long as its being done over your own private network, then no - its absolutely fine, and has no effect on your broadband usage.
To prove the point and put your mind at rest, unplug your router from the phone line and try it - you'll find it works without your web connection.
Cheesy
Unfortunately this is not possible as my set up is the following:
XBOX 360 -----> Wireless adapter ----> Wireless access point ----Wired Router
and
PC---> Wireless network card----> wireless access point ---> Wired router
Whenever I stream music my router blinks, does this mean that im using up my usage?
No, with the set up you describe you won't be using your DSL bandwidth.
Why not unplug your router from the phone line as suggested to allay your fears? Cheesy
Slick
hhmm nicely game related :p
no it wont affect your bandwidth but try
as suggested above
