setting up an Unreal Tournament Server
Glosh
Hi All,
I'm trying to get a UT server running, but I'm having trouble connecting to it from outside my LAN.
I have ports 7777 - 7781 UDP open and forwarding on my router as suggested elsewhere, but I can't connect. Does anyone know which ports I need to open to get UT up and running?
Cheers
Glosh
RE: setting up an Unreal Tournament Server
Depending on the router, you may also need to allow these ports through the firewall.
The SAR715PV is like this. Once a port has been forwarded, the firewall also needs adjusting.
Why a wizzard to intergrate the 2 steps isn't made, I don't know.
> Hi All,
> Cheers
> Glosh
you need these ports for:
UT: 7777 too 7781, TCP: 27900, 28900
UT2003: UDP Ports: 7777 too 7788 & TCP Ports: 28900, 28902
for more info:
http://www.planetunreal.com/TheAdminPage/BehindaLAN.htm
or
http://www.unrealadmin.org/modules.php?name=Sections
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Glosh
thanks for that gus, I'll give it a go.
I am right in thinking that the WAN ip address reported by my router is the IP address that will be used to access my UT server from the internet?
Cheers
Mark
> Cheers
> Mark
yes but you should forward the UT ports for each lan IP, from the router. Or each UT installed wont see or be seen
