server problem
server problem
Ever since i got a router i have not been able to host servers on halo or battlefield 2 no one is ever able to join..before i was just using a regular adsl modem....
Is my router blocking people from joining my server i so are there setting that can be changed....Any help would be great thanks Smiley
Also my router is a netgear DG834..thanks
server problem
to host a server you need to expose certain ports to the internet. by running your internet connection through a router the router is the exposed interface. you need to forward the relevant ports from your router to the local network IP address of the machine running the game server.
the ports will most probably be different for each game.
server problem
Thanks a lot most appreciated will try that when i get home from work thanks again Cheesy
Mark64uk
server problem
I used this site for advice when i needed to do this
http://www.portforward.com/
Mark
server problem
thanks will try that now Smiley
server problem
Thanks that really helped im now running servers again Cheesy
