running a mud on my machine
PhillipH
heya
ok ive set up a mud on my computer (multi user dungeon) and i can connect to it myself of my own machine and everything is great.
however - nobody else can connect to it.
is this a dns problem? or dont plusnet allow such things?
if i need to reconfigure my router i need help with this.
thanks
PhillipH
RE: running a mud on my machine
ok well it appears that it is indeed a adsl problem.
if i connect using my dial up - other ppl can connect to the mud happily.
so what is it i have to do wif my adsl for that to accept ppl connecting to my port 4000 ?
thanks
I'm not a expert or anything ... but, if you are running ADSL through a router, it mught have automatic firewall built in (my Speedtouch 510v4, did). You might have to open port 4000 (if that is the only one you want to use) and for that you'd need to look up help pages for your router.
Otherwise, i'm as clueless as you :| ... but, good luck.
A Zaman
> heya
> thanks
