ps2 traceroute trouble
I'm letting the ps2 automatically run the network diagnostic tests and when it gets to traceroute it turns red after a while, every other test is green.
I've got a safecom adsl router with a 10m cat 5e patch cable running from my router to the external network adapter. xpsp2 2ghz p4 512mb ram was plusnet premier 0.5megabit before automatic upgrade to 2megabit now PlusNet Broadband Premier Option 1.
do I have to open ports or allow access to a certain ip?
i'm running xp firewall plus my routers firewall.
hope someone can help, it's my first time to online gaming. Shockedops:
not sure about the SafeCom range, but is there anyway you can put the IP address of your PS2 in what's called the "DMZ" and trying that? You may need to assign your PS2 a Static DHCP address so you know you're definitely putting the PS2 in the DMZ.
i'll look through my routers setup.
